Question about Canon ImageClass MF6540 Copier
How can I fix error E197 on my Canon imageclass MF6540?
It comes up E197, sometimes comes up "paper jam on left side" with the red error light flashing. I unplugged it and it worked, but just for a little. How do I fix this?
SOURCE: I have a Canon Pixma
It was covered by Staples Extended warrantee and they exchanged it.
Posted on Nov 15, 2008
SOURCE: Printer System Error E197
I have a Canon MF6500 Series and received this System Error E197 error while printing a document from Word. I was low on paper in the tray but not out so I refilled the paper tray and turned the printer off for about 30 seconds and it worked fine after that. I guess I'm lucky.
Posted on Dec 05, 2008
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
SOURCE: Canon ImageClass MF6540 scans but has error light
use your computer go to command promt and do ping to copier machine ip add, see there is any reply .If there is reply ,your machine is connected to your p.c.then use the printer driver do a test print.
Posted on Sep 06, 2009
virtualhost
  • 2185 Answers
SOURCE: cannon imageclass mf3240 laser printer paper jam
Hello there,
Hope I could still share with you this fix because this is where you need to look at when you think you have done everything to remove the paper jam.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
You can also click on this link for this trick.
http://www.fixya.com/support/r3827902-canon_imageclass_mf3240_paper_jam_fix
Posted on Jan 09, 2010
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
on Jan 07, 2010 | Office Equipment & Supplies
Service manual mf6540 canon
hello friend, you can find the canon mf6540 service manual in below link:
Canon imageClass mf6540 service manual:
http://goo.gl/kW6ZF5
thanks
Apr 22, 2012 | Canon ImageClass MF6540 Copier
Tengo una image class mf 6540 marca error E000 NOSE COMO QUITARLO
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Sep 28, 2011 | Canon ImageClass MF6540 Copier
I have a Canon ImageClass MF6540 and there is a paper jam just before the paper exits the copier. There is no paper that I can grab onto to pull it out. Is there a way to over ride the machine thinking...
if there isn't any paper leftovers in copier, the problem can also be in the paper pass sensor ( fllaper ) in fixing section.
Open the left cover and rise the cover of fixing unit. Now you are able to see the flapper in the middle of unit . Try with your hand to move it. If the response is slow or you have the feeling that is broken you probably need to replace the flapper and spring.
It's hard to explain like this without picture...
For service manual you can write me on emma.servis@gmail.com
Aug 03, 2011 | Canon ImageClass MF6540 Copier
The copier red light is on after I took the paper jam out
Could be one of two things. You may have to turn the printer off to reset the light, or there might be a small piece of paper lodged inside that you can't see or reach. I had to call the repairman today for a similar issue with my Oce printer.
Feb 10, 2011 | Canon ImageClass MF6540 Copier
My Canon MF6540 is only pulling paper about 3/4 of way through when I am trying to scan/copy. There is no paper jam, and I have cleaned the machine. What could be wrong?
Does machine eports some eror like paper jam or similar o e001, ...
Check the paper sensor flapper on fixing unit, or clean all rollers with alcohol or water
Jan 29, 2010 | Canon ImageClass MF6540 Copier
It says there ia a paper jam and there is not one. We have looked for one everywhere and can't find a paper jam
open all of the paper casettes.make sure no jam there. then with the cassettes open open and close all of the covers. it is possible you have a bad sensor saying a false jam
Jan 25, 2010 | Canon ImageClass MF6540 Copier
Aug 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon MF8180c
Issue: ERROR LCD: System Error E197
Solution: Verify/reconnect power cord to fixing assembly
The power cord has been disconnected from the fixing assembly. power_cord_fixing_assembly.gif
Verify/reconnect the power cord to the fixing assembly.
May 28, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF6540 Copier Logo
215 people viewed this question
old marine
old marine
