Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
No power from transformer
Worked in home, took it on car trip, reinstalled in home and the transformer plug would not seat. got replacement transformer still won`t seat properly. if i press and hold the connector i get power, otherwise none and the connector pops out. still connects to the car plug connector.
  • hubrek Oct 27, 2008
    cut off the plastic tip of the original transformer and it works fine.
    ty ty ty.
    cut off the plastic tip of the old transformer and it works fine.
    thank you, thank you, thank you.
    Problem Solver:
  • 10 Answers
I had the same thing happen on my original Roady2. I suspect the powerplug port on the Roady2 unit is not getting a good connection. Does the transformer plug have a plastic tip? You can try to cut that off with a sharp razor blade. Sometimes that will make a good tight connection. What I did was buy a used Roady2 unit on ebay. Also another cause is
the power connection is not being made by an internal problem or wear caused by constantly plugging and unplugging the power port. I use a Cambridge XM playdock boombox at home. I bet getting a different unit will solve the problem. The only problem is that finding a used unit might take some work. Good Luck
Posted on Oct 27, 2008
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
Intermatic Malibu ML300RTW Transformer Trips curcuit breaker when plugged in. Can I assume that the 4 year old transformer needs to be replaced?
Try the transformer on different outlet.
Move wires inside breaker box to different circuit breaker.
Check is breaker is loose, or makes crackling sound.
Copy following links for resources:
http://waterheatertimer.org/pdf/How-to-find-ground-fault-in-household-electric-circuit.pdf
May 30, 2012 | Intermatic Malibu 300W Power Pack...
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
Malibu transformer 120w 1-8100-9120-01 transformer has no power and LCD is dark. Power plug was verified to be working. Unit is new, installed, configured and came back to see if lights came on during...
I don't have repair for defect timer, except return to Home Depot and exchange for another.
Try unplugging timer to see if will reset. There is no specific reset button on timer.
Test outlet with circuit analyzer to confirm there are no electrical problems.
The label shows advisories: Don't use extension cord, unplug unit when working on bulbs, and plug unit into GFCI protected outlet to protect from surge and short.
Other advisories not shown: Unplug power pack if breaker trips or if power goes out. Wait until power is on before plugging back in. First bulb should be 10 feet from unit. Do not wrap extra cord around power pack. Match bulb wattage and power pack wattage: 200 watt power pack should have 200 watts and not more or less. Replace bulbs as soon as they burn out.
These advisories should not affect initial operation of timer, but are things that shorten life of power packs,
Open following links for resources:
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#dawn-dusk
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
I have a ML300RTW Malibu transformer (S/N ML300RTW) that I bought 7/31/08. I'm pulling 170 watts from that transformer. I purchased new trippers from Northern Lights Electrical Supply. I have replaced...
You can buy cheap plug-in timer, set power pack to override and then plug power pack into cheap timer.
Otherwise there are no repair parts for power packs other than on-off trippers.
Power packs come with 5 year limited warranty, so you are within warranty period. Good job saving the date of purchase, you outshine with that detail.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Intermatic Malibu 300W Power Pack...
NOT WORKING. PLUGGED IN BUT NO POWER... had windstorm and power outage last night.
Try resetting your surge protector if there is one. If that doesn't work try a different outlet. If that still doesn't work then the problem is either in the units transformer or in the router itself. If it's in the transformer you should be able to find a replacement at any Best Buy or Walmart. However, if it's in the router, about your only real option is replacement.
Nov 16, 2010 | D-Link DI 514 Wireless Router (DI-514)
Timer stops at on and off trips and doesn't turn on or off
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
Jun 23, 2010 | Intermatic Malibu 300W Power Pack...
Transformer tripped out and radio stopped working
I had this same problem with mine. Was plugged into cord and shorted out, took back to Home Depot and got it replaced. There is an internal fuse that u can not get too no matter how hard u try to take apart. Only mfg can repace.
Jul 11, 2009 | Hand Tools
I press power button and does not start up I've
check out let for power -plug in light it works then u need voltage testor and test plug at printer and compair to settings on transformer if it matches bad printer if it does match bad transformer, bad printer do not repair costs more to fix than getting cheap printer transformer no good then check prices first, maybe till cheaper to buy printer , if outlet doesn't work check main fuses and see if one is tripped if yes reset if not bad outlet or wire, replace outlet $1 to buy if bad wire need and electrician or use extension cord to another outlet
Jul 07, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Wiring diagram for PowerBright VC-1500W Step Up&Down Transformer
I just had a similar problem but only a couple wires popped out. I took a guess at where they came from and it works again.
Top right corner - left hole - black wire
Middle, right side - left hole - brown, right hole white
bottom centre - left hole - blue and green, right hole yellow and green
Apr 03, 2009 | PowerBright Power Bright PW200-12 12 Volt...
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
214 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
