Question about Saws
Require maintenance, troubleshooting manual to diagnose a "raspy" noise emanating during "free" (not cutting wood) operation
This saw has relatively few operating hours; yet, it has been in (box) storage in cool, dry space for years..............Perhaps extreme (winter-summer) temperature fluctuation has affected (stator-rotor) clearances or the brushes themselves. Upon startup, there is no unusual vibration or looseness of the arbor-blade assembly. It "freewheels" (after release of the ON/OFF switch. However, comparing (sound) this saw with an identical saw, when powered, it has a much more profound, constant, "raspy" noise.............Please advise Robert J Blaskowski
  • David Ford
    David Ford Mar 01, 2012
    I am thinking that you have a bearing issue but without a brand and model number I can't assist you in locating a breakdown. Let me know what the brand and model number and I will try and locate one. I can't respond directly, I have to do it on this site.
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
  • 2176 Answers
SOURCE: Problem finding blade choices for Makita circular saw
OK done some more checking and I believe you are out of luck, but before giving up hope do you have a saw sharpening business in your area?? My friend says that he has sent blades to one in my area and had the center hole bored out to the appropriate arbor hole and the blades run true and from what he tells me it is relatively cheap, so check first and see and then you can buy a blade in the diameter you want and have it bored out. Sorrry I couldn't come up with anything else, I check about 6 diffferent mfrs and they all have the same.
Posted on Jan 21, 2009
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
  • 376 Answers
SOURCE: instead of cutting, my saw burns the wood and makes
Sounds like a very dull blade.
Posted on Jun 30, 2009
  • 5603 Answers
SOURCE: ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Posted on Sep 28, 2009
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
I have a black and decker jigsaw that the plate you put on the wood moves and the cut angled and I do not it to?
Hi John:
These saws are usually really reliable, and SOLID.
I'd suggest that you UNPLUG THE SAW and then explore a bit. Look for loose bolts at the pivot points, or possibly a poorly fitted bolt. If this is your saw that you have had for some time, you should know what maintenance has been done that possibly caused this problem.
Oct 03, 2015 | Saws
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
Screeches when I cut wood
open the front and watch it when you turn on sounds like you have a piece of wood stuck somewhere
Apr 01, 2015 | Central Machinery 9" Bench Top Band Saw
Is it better to do pull cuts or push cuts with a hand saw?
it is a matter of debate, and ultimately up to your personal preference. i keep a steady pressure on the wood at all times, so the saw cuts during the push and the pull
Jan 28, 2013 | Saws
What gas to use for TS350
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
Jul 20, 2011 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
Cutting with my saw and it just dulls for no weird noises or anything.
You do not say what kind of saw it is or what type of material you are cutting. It could be dirty wood, hard wood, wrong cutting speeds, hard metal, anything, Please supply some more specific information for a thorough analysis of your problem.
Apr 04, 2011 | Garden
Bought the makita 18 volt lithium power saw which i thought would cut a 40mm worktop in fact i struggles to cut 9mm ply is this it's limit or is there something wrong with the batteries
I have a Ridgid brand battery operated circular saw 18 Volt and it works very well for a battery operated saw. It eats 2x4's and 2x6's very well. I have noticed that when the blade only gets slightly dull it will not cut worth a darn. Keep a sharp blade on it and maybe try a different battery. A battery powered saw is NOT a replacement for a plug in saw, but they sure as heck are handy.
Cutting a 40mm worktop should be no problem unless it is a hard wood. If it is a hard wood you might need to get a plug in saw and a very good blade.
Nov 03, 2009 | Makita BL7010 7.2V Lithium Ion Battery
I am running a six inch blade width horizontal band saw in a sawmilling application, resawing flitches to thinner boards. Average depth of cut about eight inches. What blade life (swage set steel) should I...
This depends on the type of wood you are cutting. Hardwoods , like oak, will dull the blades faster and require a change after about 3 months if used daily 8x7 but you can get a longer cutting time IF the blades are carbide steel. You can add life to the saw teeth by keeping them clean and free of sap buildup too.
Specially when cutting pine.
Jul 12, 2009 | Saws
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
