Question about Ironman 220t Programmable Treadmill (225 HP)
Ironman treadmill shows code SI 1. what is it? how to fix?
    Problem Solver:
  • 6 Answers
The SI 1 error code means there is no safety key in place. Unplug your treadmill, wait a few minutes, then plug it back in.
When you try to use it again, make sure the safety key is firmly in place, and make sure the metal piece below the Emergency Stop sticker is still in place.
If neither of these work, it may be appropriate to take your treadmill to a servicer.
Hope this helps!
Posted on Feb 21, 2012
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
SI 2 - Over voltage protection trip
you lower the voltage by adjusting the TAPS of transformer inside of machine. example if the voltage input is 115vac, normally, AND now are 140 VAC, lower to 80vac in the tap , etc.
However you must test why is the reason the voltage input in your home is increased?. Call to the company electricity or some electrician for to adjust and fix it.
God bless you
Sep 23, 2012 | Ironman Exercise & Fitness
Ironman 3900 treadmill will not work. code L 14
1) adjust the speed sensor, clean and tight the wires connector very well
2) lube the gear and shaft from elevation motor
3) adjust the potentiometer from elevation motor
4) measure the input voltage from elevation motor
5) Try to run the software calibration, for diagnose, troubleshooting
God bless you
Jun 11, 2012 | Exercise & Fitness
L 14 code on ironman 3900 treadmill
1) The code change to some manufacture to other.
2) However the problem is the same
3) You must LUBE the deck belt
4) Lube the rollers bearing very well
5) Measure the input voltage motor, if there are THe motor need repair
6) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
7) However try to RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you. see the block diagram
Jun 09, 2012 | Exercise & Fitness
Si 2 error
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
SINCERELY. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Ironman Exercise & Fitness
Missing manual for Ironman 320T.Where can I find or download one?
Hi
Click the follwing link for ironman 320T manual
Ironman 320T
I hope this helps.
Dec 10, 2011 | Ironman 320T.1 Treadmill
What is it when display reading SI 2?
SI 2 - Over voltage protection trip.
Just check if there is any resettable breaker located underneath it. You also may have a cable connection loose.
if it doesn't works for you
You may need to notify Ironman Fitness Customer Service Call Ironman Fitness Customer Service at (800) 750-4766
Mar 14, 2011 | Ironman 220t Programmable Treadmill (225...
Error code "SI 2" for ironman triad treadmill
You need to replace the motor control board located in on the base. If your both motors work along with your display added that you've done the reclibration then you must replace this board. I did and the unit works so far. 200 dollars is what you wil be spending.
Jan 05, 2009 | Exercise & Fitness
Ironman 220t Programmable Treadmill (225 HP) Logo
707 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Tony Crow
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
