Question about Pioneer SD-P62A3-K 62" Rear Projection Television
Tv turns off and wont come back on
This Tv has a habit of blowing the fuses. However sometimes it just turns off without a fuse being blown. A TV Repair Man said there were loose capacitors and the whole board needed to be resoldered. Another one said a tuner cartridge needed to be replaced. Right now it will come on for a few minutes and then cut off and all the fuses are fine.
  • Anonymous Dec 03, 2007
  • outlaw175 Jan 16, 2008
    TV will not come on. Red light on power is illuminated. When i push on , on the remote, there is a click, but the tv will not power up, and the standby light stays red. There is a clicking sound in the back that is like a clock, only faster than i click a second. I do not know where the fuses are, to check them. the first time this happened 4 years ago, a fuse repaired it. about a year later it happened again. the repair man had a lot of trouble finding the problem, and finally settled on resodering the convergence. That made it for a year. cos was around $250 Any suggestions
Mine did same thing fixed @ shop for less than 100.00
Posted on May 22, 2007
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Will not turn on, no blinking lights, power coming from cord is good
Sounds like the power supply board is dead. Probably has a blown power line fuse on the board. A power surge will sometimes blow the fuse and protect the board from damage. Replacing the fuse will restore the TV if this is the case. Most times though, the supply has a blown part that causes the fuse to blow and your only option then is to replace the board.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
While watching a movie on my RCA tv. model #HD52w59, it just lost all power and wont turn back on and the green power light does not light up. there is powere at the putlet so i know its something with the...
check first loose or broken power cord. if ok, what you can do is look for the power supply board look for blown fuse sometimes due to voltage fluctuation the fuse get blow.
Sep 17, 2012 | RCA Televison & Video
WONT TURN ON
Hello
Check the glass cartridge type, relpaceable fuse inside the Tv. This fuse can be located on the power regualtor section of the TV. Usually, it will come on the main board. If found blown up, never insert an other one, without point out the reason for the present fuse's blow up.
Mar 15, 2012 | Sharp 27L-X2000 27" TV
DOES NOT TURN ON
Hello
Open your TV and chekc whether the fuse in the power supply board has blown out or not. If it has blown out, never replace it with same type; befor troublshoot the reason for the blown out for the fuse. There must be some reason for the fuse to blow out. Without rectifying it, if you replace it with a new fuse, it may cause more damage to the set.
The power supply board to your TV will look like this.1_10_2012_4_00_19_am.jpg
Jan 09, 2012 | iLO LCT32HA36 Television
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV DEAD
On some models the reset is unplugging for a minute or two and plugging back up. Otherwise you have a blown fuse where the power goes in. If you decide to replace the fuse do no go over 5 amps. If the replacement fuse blows there is a short in the set and needs a repairman.
Jan 02, 2008 | Philips 19PR19 19" TV
Sharp TV
It could be a blown fuse, sometimes when power is restored a power spike occurs this can blow fuses in appliances. Check power to either side of main fuse. Then progressivly check all other minor fuses Cheers Paul
Sep 17, 2007 | Sharp 27H-S200 TV
Tv wont turn on
Hello tvlover, The outage actually is not the problem but the spike that happened when your power came back on did the damage. That aside, you may just have a blown fuse. If you are able to and feel comfortable work with electronics, with the TV unplugged from the wall, take the back off of your TV and take a look at the line cord going into the circuit board, this will lead you to a fuse holder, look at the fuse and see if the filament inside has been blown (opened). If the fuse is blown relace it with one of the same amperage and voltage which should be written on the metal part of the fuse. Once the fuse is replaced, plug the power cord back into the wall and power it up. If it comes on and plays, that was your problem and you can turn the TV off unplug it and put the back cover back on, plug your TV back into the wall and enjoy. However if the fuse blows again, that could indicate a problem with a short somewhere in the powersupply path and that will require troubleshooting the set. Now I we have to troubleshhot this TV you will need a multimeter, an oscilloscope, and a schematic of the TV (at a minimum). If you do have electronics experience to this level and do not have this type of equipment, You will have to take the TV to a repair shop. Thank you, and I hope that it is just a blown fuse.
Aug 25, 2007 | Sansui DTV2760 27" TV
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
135 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
