Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony model # KV27S20 1991 TV - Sony FD Trinitron WEGA KV-27FS200 27" TV
How to connect HDTV antenna to an old Sony Am Fm Radio Tv Receiver, Model Tv-413?
yes there is an coax to ant adapter. Check walmart or Radio Shack if they are still in business.
Apr 06, 2015 | Sony Am Fm Radio Tv Receiver, Model...
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
"TV Volume is fixed" shows up on Sony model #
Go to Audio Menu and turn On tv speakers option. "TV Volume is fixed" message will disappear.
Click Sony Support link to download user manual copy of this tv and check page-63 fro more details.
Thanks.
Dec 29, 2010 | Sony Televison & Video
I need circuit diagram of T.V sony WEGA 14inch
Let me know model number of your tv, I can provide you scehamtics for that one.
Thanks.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Sony kdf 50e standby light flashing 2 pulses
If your tv is Sony KDF-50E2000 model then 2 times standby light shows problem of over temperature in tv. Check temp sensor in tv.
If model number is different, let me know complete model number written on label at rear of tv to help you out.
Thanks.
May 14, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
VOLUME CONTROL
I HAVE SONY TV MODEL 2197.WHEN I SWITCH ON THE TV NO SOUND INSTEAD OF THAT I PRESS FULL VOLUME ...
Jan 27, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
Jan 14, 2009 | Sony KV-32V16 TV
Sony tv model kv-27HFR
hi can you send me a tv diagram for sony tv model kv-27HFR cause there are components missing and...
Feb 26, 2008 | Sony Televison & Video
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
