Why am i not getting the internet from my verizon wireless router
Power light is stable green dsl light is blinking and my wireless light is stable but no internet.
    Master:
  • 451 Answers
If the dsl light is blinking that means it is trying to obtain a connection with your ISP. check ot make sure that all your phone lines have a filter on. contact your ISP to see if there is any quality issues with your connection.
Posted on Feb 22, 2012
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
Posted on Jun 09, 2008
SOURCE: Westell 327 wireless router
I found a solution for this problem. After complaining to Verizon Tech support, I finally got someone to listen. I talked to a Tech that I think was in India, nice lady that walked me through all the line test and finally a modem test. My connection keep dropping through the modem test, which I had a feeling the real problem was. I was told the modem was out of warranty and would cost $59.00 to replace at first, but after calling in so many times this lady sent me a new modem, not a 327W, a 7500. Disconnected the old modem, installed the new one and so far no more dropped connection problem.
Posted on Aug 01, 2008
SOURCE: Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Posted on Aug 01, 2009
sitehr
  • 94 Answers
SOURCE: My router is not broadcasting wirelessly
their is option in setup to enable wireless or disable it go to modem setting page and enable wireless function
Posted on Aug 17, 2009
arvinds88
  • 108 Answers
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Posted on Jan 15, 2010
Internet explorer doesn't display any more i can't open my hotmail/msn, ni gmail. help me
HI there
Internet Explorer is the problem. Down Mozilla Firefox (obviously from another computer) onto flash disk (memory stick) and install it on your computer. it is a lot more stable, and it free download from www.firefox.com
regards
Andre
Sep 09, 2011 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
How to troubleshooting DSL conection
Hi.
look at your dsl L.E.D
if the lights blinking, meaning there is a problem on the DSL line and you need to contact the service line provider to solve your DSL line.
(Good
DSL line if the DSL L.E.D light is not blinking led (stable)
regards
Aug 04, 2011 | D-Link DSL-G604T Wireless Router
How many lights should be on my westell model327w?
The Westell has several lights on the front that have various meanings
Power = When lit, this light indicates there's power to the router. It should be solid green.
Ethernet = When lit, this light indicates that the modem is communicating with your computer. This will be on only if you're using the Ethernet cable to connect the modem to your computer
Wireless = When lit, this light indicates that the wireless function of the Actiontec is working. This will only be lit if you're using the wireless function.
DSL = When lit, this light indicates the modem is speaking to the central office (phone company). When working, the light should be solid green.
Internet = When blinking, this light indicates that you're receiving information i.e., you're able to browse from site to site. This light will be blinking as you're receiving information.
Sep 16, 2010 | Computers & Internet
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Jul 11, 2009 | Westell Wirespeed VersaLink...
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
