LexmarkX4580 lost wireless network connection
Had some problems with Belkin Wi Fi - now sorted, but the printer does not seem to connect
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
TCP/IP Lan
Network Printer...this does not apply to USB / Parallel Cable connected printers.
This is a brief explanation of why a network printer might not be printing; this is not a simple explanation. There are many variables, this is the most common.
This is one of the most common mistakes with Network printers.
A Network printer should bet set to a Static IP address (or fixed address)
Terms:
Dynamic Host Configuration Protocol (DHCP)
The Dynamic Host Configuration Protocol (DHCP) automates the assignment of IP addresses, subnet masks, default gateway, and other IP parameters.
Static IP addresses
When a computer / printer is configured to use the same IP address each time it powers up, this is known as a Static IP address.
Regardless if you printer is Wireless, or connected with a LAN cable to the Network.
The PC has a specific fixed location / address to find your printer; this was assigned when the printer was installed
(This can be found in the print driver under ports tab, something similar to 192.168.x.xxx, this is the IP address of the printer when it was installed)
If your printer is set to use DHCP, it will reassign a new address every time you reboot, shut down or there is a power loss.
(You might get lucky and it assigns the same address as previously assigned)
The PC will look to the address it was assigned at the time of the install and not the new reassigned address.
This assigned port in your printer driver is not capable of searching and updating the IP address of the Printer. This is not a Plug and Play item; it is not directly attached to the PC through Parallel Cable or USB.
If you reinstalled the printer after your system rebooted, you probably have the printer installed more than once. One works the other doesn’t! One has the correct address; the one that doesn’t work has the incorrect address.
If you do not set the printer to a static IP address this probably will happen again when it is restarted or there is a loss of power.
How to Fix this Problem:
1. Assign the printer with a Static IP address.
Read the manual specific to your machine, sometimes this can be found in the Set up Guide, or Administrators guide.
This setting can usually be found in the network settings of the printer.
You will also want to set the subnet mask, and the default gateway.
Which can be found using a PC? Click start, Run, type in CMD, and new black window will pop up, type ipconfig/all press enter, this will show all the network information you will need for this.
2. Making your PC communicate with Printer:
There are a few ways to do this, the easiest is to delete the old driver / printer and reinstall the driver. Most manufactures provide an automated click next type of install software. (Search their website for this)
You can also go into the printer ports of the driver and create a new port using standard TCP/IP port, and reassign to the new port.
This link is a to finding your print driver / print folder using a PC.
http://www.fixya.com/support/r1173318-print_driver_location_pc_print_test_page
A patch cable directly from your PC to Your printer will not work; it will work with a crossover cable and a few minor changes to the TCP/IP settings. (You might get lucky using DCHP on the PC Side)
There are several ways to Network a printer.
Printer connected to Router etc…
The other way is P2P, or a shared printer
The Printer is shared from a PC / Server, which the printer can be connected directly to the Sharing PC via Parallel Cable, USB, or Networked through a router as discussed above.
In this Shared connection an administrator has control over the printing abilities of others that are using the printer.
The down side to this type of connection: if that PC / Sever is not powered on, having printer connection problems, or not connected to the network. Any PC which is using this shared connection will not be able to print.
I hope this helps, if you need any further assistance, let me know.
Posted on Oct 27, 2008
Wii-fi will not turn on
Let me know the device you are using
Jul 13, 2015 | Google Android
How do get wi-fy on my tablet?
It's a good idea to access Wi-Fi whenever possible to avoid data charges. After you've activated the Android tablet's Wi-Fi radio, you can connect to an available wireless network. Obey these steps:
  1. Open the Settings app.
  2. Choose Wi-Fi.On some Samsung tablets, you find the Wi-Fi item on the Connections tab. Choose Wi-Fi to view a list of available Wi-Fi networks on the right side of the screen. Otherwise, the list shows up full screen.
  3. Choose a wireless network from the list.When no wireless networks are listed, you're sort of out of luck regarding Wi-Fi access from your current location.
  4. If prompted, type the network password.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
  5. Touch the Connect button.
    The network is connected immediately. If not, try the password again.
When the tablet is connected to a wireless network, you see the Wi-Fi Connected status icon. This icon indicates that the tablet's Wi-Fi is on, connected, and communicating with a Wi-Fi network.
Some wireless networks don't broadcast their names, which adds security but also makes connecting more difficult. In those cases, touch the Add icon. This icon might also be labeled Add Wi-Fi or Manually Connect. To make the connection, type the network name, or SSID, and choose the type of security.
You also need the password, if one is used. You can obtain this information from the girl with the pink hair who sold you coffee or from whoever is in charge of the wireless network at your location.
  • Not every wireless network has a password. Still:
  • Be careful when connecting to a non-password-protected network. It's possible that the Bad Guys can monitor such a network, stealing passwords and other information.
  • Some public networks are open to anyone, but you have to use the web browser app to find a login web page that lets you access the network: Simply browse to any page on the Internet, and the login web page shows up.
  • The Android tablet automatically remembers every Wi-Fi network it has ever been connected to and automatically reconnects upon finding the same network again.
  • To disconnect from a Wi-Fi network, simply turn off Wi-Fi.
  • Use Wi-Fi whenever you plan to remain in one location for a while. Unlike a mobile data network, a Wi-Fi network's broadcast signal has a limited range. If you wander too far away, your tablet loses the signal and is disconnected.
Oct 29, 2014 | Nextbook Premium 8 Se Android
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Router light turned into orange after changing password. i changed my router password and when i saved the new password the website told me something like 20 secs remaining. i had no idea what to do a
Sir
Please proceed with the instructions below.
Step 1:
Enable the Wi-Fi feature of your mobile device. Look for the wireless network name (SSID) of the WeMo Light Switch which will be WeMo.Light.xxx and tap it to connect your device.
QUICK TIP: If you have multiple WeMo devices, connect to the one with the same WeMo ID at the back of the device. The WeMo ID is the word WeMo followed by WeMo model,and then three (3) alphanumeric characters.
NOTE: To know how to enable the Wi-Fi feature of your mobile device, refer to your device\'s manual.
Wait until you are connected to the WeMo Light Switch network. A successful connection is indicated with check mark beside the WeMo Light Switch (SSID).
Step 2:
Launch the 7c714365-1d70-4873-b4f9-e5ddfff23375.pngApp.
Step 3:
Tap the wireless network name (SSID) of your router and enter the password when required.
NOTE: WeMo can only connect to your 2.4 GHz network.
Wait while the WeMo App attempts to connect. If the WeMo encounters difficulty connecting to the Wi-Fi network, try refreshing your mobile device\'s Wi-Fi and try connecting again. For more troubleshooting instructions,Click Hear,
The Remote Access Enabled message will then pop up. By default, the Remote Access feature is enabled.
Step 4:
When the WeMo Light Switch setup is completed, tap Done after viewing the information of the device.
QUICK TIP: You can customize the Name, Device Icon, and Email of your WeMo Light Switch. It is recommended to enable the Remember Wi-Fi Settings option so the WeMo App will automatically connect to your wireless network once it is in range.
The WeMo App will then refresh, look for devices and automatically detect your WeMo Light Switch.
You should now have installed the WeMo Light Switch with the WeMo App.
With the WeMo App, you can create different rules for your WeMo Light Switch.
If you Still having Belkin Basic Wireless Router Problem then visit official Belkin Website Support Belkin Problems,
Or
In Case You still need online Belkin Router Help,then follow us on for Belkin Support
Feb 27, 2014 | Belkin Basic Wireless Router
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    As soon as i went from a 'B' to a 'G' router, my internet has slowed dow , worse than dial-up
    The Belkin Wireless G Router lets users share files and a broadband Internet connection among their computers-without using networking cables. It features 802.11g technology that makes accessing files and networked peripherals-such as hard drives, printers, CD-ROMs, and DVDs-easier than ever. 802.11g technology provides you with networking speeds nearly five times faster than the current Wi-Fi (802.11b) standard. An integrated, 4-port 10/100Base-T Ethernet switch also allows you to connect wired computers to the network. 802.11g technology is the easiest wireless network to implement. The Router uses the wireless 802.11g 2.4GHz standard to offer you 400 feet of wireless coverage. 802.11g technology is backward compatible with the 802.11b Wi-Fi networking standard, so it allows you to implement faster wireless technologies in combination with existing 802.11b Wi-Fi networks.
    so if use "g" type router the speed cannot be slow there may be some other problem....that let the internet speed down....check that......
    Sep 19, 2008 | Computers & Internet
    Wifi issues
    i think there is some kind of block from the network administrator
    usually you can access wifi easily with out any problems.
    di u install any third party application in your phone recently??
    Sep 17, 2008 | HTC Touch P3450 Smartphone
    Password
    Ok... There are tree things you need to know about securing your WI-FI network.
    1: Each computer needs to have "permision" to access your WI-FI network.
    2: The "Passphrase" and the "Key" are not the same thing. The "Passphrase" doesn't always work. But the "Key" should. (MACs will need the "key")
    3: Some WI-FI equipment is "too old" to use 128 bit WEP or WPA.
    (I don't think this aplies to your problem)
    Nov 22, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    270 people viewed this question
    jasbo
    jasbo
