Question about Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator
Fridge is not cooling but freezer is working.
5 Suggested Answers
  • 262 Answers
SOURCE: Freezer works but not the fridge
check and see if there is ice build up on the rear of the freezer if so push in your door switch/s and see if the fan runs if not replace fan if so you have a defrost problem located behind the cover in the freezer let me know what you find and get back to me and i can help you more
bill
Posted on Jan 08, 2009
SOURCE: Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Posted on Aug 10, 2009
  • 72 Answers
SOURCE: freezer works fridge cool but not cold
Most side by side units have 2 compressor units. If you listen for it, you should be able to hear 2 compressors with slightly different pitches, operating at different times, or sometimes at the same time. If you never hear the fridge side compressor turn on, a sensor or the compressor is probably bad, if you never hear the fridge side turn off, the temp sensor is bad. If it has ever, or is leaking in the back, then there is a puncture in the cooling system, and the fridge will not be able to be cooled. If you can pull the fridge out and examine the tubes or unplug it for about 10 minutes and plug it back in to observe compressor activity and any small leaks, it would give a more definite answer to the problem. A mechanic will most likely be necessary.
Posted on Dec 04, 2009
  • 99 Answers
SOURCE: compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
Posted on Jul 30, 2010
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Open Questions:
See all Amana AFD2535FES Stainless Steel Bottom Freezer Questions
Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
89 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
