Question about Toys
Instructions for little squirt game from sainsburys
How to fill it up with water
2 Suggested Answers
  • 23 Answers
SOURCE: Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
Posted on Mar 24, 2013
Mar 24, 2013 | Maytag MSD2756GES Side by Side...
I hasve just bought a Universal Remote Control from Sainsburys UR 81LCD EDP 23042 It has no instructions with it. Dave Hazell
The instructions are usually printed on the packet it came in.
Go online to Sainsbury.co.uk to see if the instructions are listed.
Hope that helps.
Mar 04, 2011 | Televison & Video
1995 saturn My windshield washer doesn't squirt fluid. Which fuse should I check? What else should I look at?
This reply falls under, " what else should I look at."
When you press to squirt, do you hear any sound? if you do there are 3 easy things you can do.
1. Some of the windshield wiper reserviors, ( plastic bottles ), need a minimumlevel of fluid to operate, so, make sure you fill up your reservior.
If that doesn't help;
2. There is a very small hose that runs from the reservior to the pump, pull it off of the pump end, very carefully, and have someone hit the squirter.
If fluid comes through the hose;
3. Take a very small paper clip, straighten one end out, and push it into the ports that the water shoots out of to squirt the windshield.
Sometimes wax or debree can clogg these very little holes.
Jan 24, 2011 | Saturn Cars & Trucks
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
1995 BMW 525i my car over headed and it squirted out all over me. Is this a serious problem or not?
bummer . and it could be . always squeeze the top radiator hose before you open the fill cap ! if the hose is hard this meens there is lots of pressure there ! so wait till it cools then... if you fill it back up with water and it you bleed it OR take the thermostat out and run it for 5-10 minutes enough to get the cooling fan to come on if applicable and if the hose is hard. you may have blown a gasket or cracked something. in this case go to your local auto parts store and ask the for KW BLOCK SEAL AND FALLOW THE INSTRUCTIONS TO THE LETTER.. YOU CAN LEAVE IT SET LONGER TIME AFTER DRAING . I DO AND I HAVE HAD BETTER LUCK I'VE DONE 50 OR SO CARS AND FIXED ABOUT 45 OF THEM WITH THIS LITTLE TRICK .. GOOD LUCK .. Jay
Feb 14, 2010 | BMW 525 Cars & Trucks
Alfa 156 motor system control failure message
I Think it's just conincidance. Sainsburys fuel is checked independantly by Trading Standards and a private company. Both turn up unanounced. Plus there is a warning in the stations if water etc. is found. This shuts of the fuel from that tank.
Jun 02, 2009 | 2000 Alfa Romeo 156
Model 1400 little green cleaner does not squirt fluid
its just the prime.if all the water is let out of the hoses it will need to be reprimed with water again.once water fills the hoses it will work fine
Dec 10, 2008 | Bissell 1400 Little Green Pro Canister...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Toys Logo
135 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
