Question about Air Conditioning and Heat for Saturn Outlook
Whit smoke comming out of my duck
When i had my ac on white smoke not smelling smoke came out of the front air duck now my ac not cold
  • 21 Answers
Probably bad seal in A/C compressor Saturns are known for that. system needs to be evacuated and put into a vacuum to see if it holds it. Then u can go from there.
Posted on Feb 21, 2012
Testimonial: "i would like more info please"
  • Gino Bud
    Gino Bud Feb 21, 2012
    could it be anything else
  • W R Smith Feb 21, 2012
    If your a/c is not cold, start car turn a/c on max pop hood u should be able to see a/c pump it has a clutch on the frnt of it it will eithr be turning with the pulley or not, if not which i'm pretty sure then your a/c pump imploded internally.
I have a 2006 crown Victoria and I have a little bit of white smoke coming through my vents for about 10 seconds what could it be? When I had my ac on I heard a pop but no smoke. What could that be?
Some car air conditioners are on by default on some settings. This could be really cold air blown out when the fan comes on. Check to see if the smoke is cold.
Aug 29, 2015 | AC Cars & Trucks
I have a Ford Focus 2.0 litre zetec engine on a x plate. When I start it up from cold it bellows out white smoke for about 2 mins then clears and is fine until the next day. It is not losing water and is...
White smoke on start up of a cold engine is water vapour created by cold moist air and hot combustion ( steam). Mostly all cars will emit a whit wispy smoke until temperatures are elevated enough for the cat converter to turn it in something you cannot see. To be sure have a compression test done to check for gasket and have a coolant system pressure test done to check for coolant leaks
Dec 16, 2014 | Ford Focus Cars & Trucks
White smoke from air vents while ac was on,greasy film on window while defrost is on/heater coil?
Yes. The heater core is leaking bad. The white smoke is the coolant and steam. Be sure to add water to the radiator before you burn up the engine.
Oct 19, 2014 | Cars & Trucks
4g15 engine carburetor smoking only when engine is cold
smoking from where?, front of car, middle or tail pipe.
is this your first car, or first car and first winter (white steam?)
there are 3 kinds of smoke
black , carb flooding (ask why)
white, oil, burning, take for ever to go away
white steam, goes away fast and smells like Antifreeze, sweet and nasty.
and all carbs smoke black in the tail pipe end, when cold, unless
you very carefully tune the choke plate.
so do tell? what?
Jan 04, 2014 | 1995 Toyota Hi-Ace
Smell and white smoke coming thur ac vents
Your heater core has developed a leak (of coolant). The smell is the "sweet" smell of ethylene glycol,
a component of engine coolant. The white smoke is steam coming from the heated coolant evaporating.
The coolant is dripping into your duct work under the dashboard, and apparently being evaporated
out of the ductwork and sent into the passenger compartment, meaning its a small leak.
When the leak gets worse, you may get wet carpet on the front passenger side.
Jul 20, 2011 | 2000 Ford Crown Victoria
White smoke from exhaust pipe..
White smoke is a sign of coolant being burned in the exhaust.
Jul 05, 2010 | 2003 Ford Explorer
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
My 99 cougar smokes
You have to determine why it is smoking and what the smoke means. White smoke almost always means you have coolant entering the combustion chamber. The exhaust will smell sweet. I am not referring to the white smoke you see when it is cold and stops after awhile, as that is condensation. I am talking about white smoke you see when it is not cold. Stop driving the car immediately or you will have serious engine damage.
Black smoke is the result of an overly rich fuel/air mixture and can be caused by many things.
Blue smoke is an indication the engine is burning oil. Normally caused by worn piston rings.
Jul 09, 2009 | 1999 Mercury Cougar
Ac was on air was comming out then white smoke came out
If there's white smoke, you A/C motor may be overheating and in need of replacement. I have found that usually occurs when the thermostat is left to ON and Cool for days without providing the A/C a chance to "rest." After replacing the motor, remember to set the thermostat to AUTOMATIC at a temperature of about 70 degrees or so, so that it only works when the temperature in your house is about 70 as opposed to working constantly, which is unnecessary and a real drain on your A/C's ability to function. Here's a great handyman site that has a section devoted to A/C issues:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning.htm
The site linked above includes informative articles and even, if all else fails, ad links to local A/C technicians who are willing to give free estimates--up to four
Brad
Jul 04, 2009 | Heating & Cooling
Could be an incorrect refrigerant charge or defective pressure switch causing the evaporator to freeze and the air flow over it is causing the ice to melt and the resulting white smoke is condensation
May 15, 2008 | 1990 Volvo 240
Air Conditioning and Heat for Saturn Outlook Logo
259 people viewed this question
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
