Question about Water Heaters
Worcester 28i central heating system is 'kettling'
Hi there.. I have a Worcester 28i Boiler. A few weeks ago it started 'kettling' so it was drained and re-filled with a cleaning additive included. I've just fully drained the system after leaving it a week and a half with the cleaner running through it. The kettling noise had gone and it was back to running smoothly. After draining the full system and radiators, I then re-filled with an inhibitor included, but the kettling noise seems to have returned with a vengance too.!! Alll radiators are fully bled now and the system is at 1.5bar when cold, rising to 2.5bar when hot. Is there any reason the system would be ok with cleaner inside, but not after a drain and refill?? Any help would be most welcome.. Thankyou.
  • 13 Answers
SOURCE: Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Posted on Mar 03, 2009
gary1121
  • 332 Answers
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Posted on May 29, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
mrhotandcold
  • 248 Answers
SOURCE: bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Posted on Oct 11, 2009
mrhotandcold
  • 248 Answers
SOURCE: worcester oil heatslave boiler pressure rises to over 3 bar when
iif you,ve tried everythng change gauge
Posted on Oct 12, 2009
I have a Worcester 28i combination boiler. What shower mixer would you recomend
Delta brand is good and reasonably priced. As to model you need to choose based on aesthetics of your tastes
Nov 15, 2016 | Water Heaters
My Worcester Bosch green star 28i keeps losing pressure,I have changed the expansion vessel about 6 months ago any idea.?
Check for water leaks on the system also check pressure relief it may be passing water .
Oct 20, 2016 | Bosch Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
A trickle of hot water from taps, central heating ok
May 18, 2009 | Water Heaters
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
Worcester greenstar hot water fluctuation
the limit stat could be out of calibration, low water rate, by/pass if fitted may need reculated, could be blocked heat exchanger best of luck
Mar 03, 2009 | Water Heaters
Water Heaters Logo
102 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
