Question about Frigidaire Refrigerators
Frigidaire ss FRS6HR4HW6- freezer working great-no frost fridge not getting very cold- have turned up thermostat and still not getting colder-seems to kick on alot, but no temp change.
  • Frigidaire Master
  • 4,655 Answers
It is possible that the freezer will appear to be working normally while behind the rear wall of your freezer the evaporator coil has not been defrosting. Click Here=> Evaporator Coil Not Defrosting
When this happens the first thing you or most people see is fresh food temperatures begin to warm. This is caused by lack of air circulation. The key part that has failed is called a Adaptive Defrost Control and will be found inside your fresh food compartment and listed as item location 23 Click here=> FRS6HR4HW6 Controls
242011001 Defrost Control Board
and in some cases the 241600905 Damper Control Assembly or item location 115 in the FRS6HR4HW6 Controls
photo. I will be here should you have any questions. If helpful please rate this solution, Thanks Sea Breeze
Posted on Feb 22, 2012
HVACRH20
  • 237 Answers
SOURCE: GE Fridge/Freezer Having to turn temp up just to keep it cold
That's a typical sign of the defrost cycle not working and ice is building up on the coils. That prevents proper air flow of cold air around the compartments. As ice builds up you get less air flow and things warm up soooo you turn up the cold which causes more ice to build up and even less air flow soooo you turn up the cold. See where I'm going with this? You'll have to check your defrost timer, defrost t-stat and even the heat element. Look in your owners manual or online for diagrams of where the parts are located on your older unit, then go from there.
Posted on Dec 30, 2006
Krazytech
  • 725 Answers
SOURCE: Whirlpool fridge to cold
Both the thermostat and Adaptive defrost control are inside the fresh food compartment on top..
also check you damper it it is closing
let me know
Posted on Apr 05, 2008
NorseXNW
  • 8 Answers
SOURCE: frost forms in freezer, blocking vents so temp in both freezer and fridge is warmer than normal
You have an issue with the defrost system, either the timer, thermostat or heating element. Probably the defrost timer refer to the manual to find it. If you don't have the manual check the makers web site for a parts breakdown. You should be able to put it into defrost manually by turning the knob and see if that helps. You may need to do this sevral times as it only stays in defrost for a little over twnety minutes and run cycle for 6,8 or ten hours. If the ice build up is heavy then twenty minutes may not do the trick thus the need for repated defrost cycles. If it does the trick replace the timer. If not check the thermostat and heater element.
Posted on May 23, 2009
aasc
  • 1606 Answers
SOURCE: Motor not going on at all anymore
need brand and model number .
Posted on Jul 21, 2009
  • 351 Answers
SOURCE: little fridge is freezing -
higher is colder
Posted on Oct 08, 2010
Sounds like it's working but not getting cold enough in freezer or refrigderator
In my experience, the biggest culprit causing these symptoms is the defrost heater. This is a heating device that melts frost off the "evaporator coils" better known as the coils usually located inside the freezer area of the unit. These coils get very cold and warm air that is let inside when any door is open, will carry moisture with it that will accumulate like water on the outside of a cold glass in summer time, only it accumulates on the evaporator coils and turns to frost.
As your fridge cycles through its operating stages, one part of the cycle turns off the cooling and turns on a heating device of varying types to melt the frost and ice off of the evaporator coils so it can drip down and flow through a small hose through an opening in the bottom of the fridge and into a pan underneath the fridge where it evaporates back into the air again.
If the heating device never comes on, or becomes inoperative, the frost will slowly continue to collect on the evaporator coils until it becomes a solid block of ice. This now greatly reduces the ability of the evaporator fan to blow the cold air around the coils throughout the freezer and the rest of the fridge. The ice built up around the evaporator coils will still provide some cold, but will significantly prevent the fridge from operating properly.
Another cause may be the evaporator fan not operating correctly. If it doesn't blow air over the evaporator coils well enough, cold air will not get distributed through out the fridge. Cold air tends to "fall", so the bottom of the freezer will be the coldest. Generally, there is an adjustable hole in "side by side" units so that the amount of air coming through that hole can make the "meat crisper" colder. In fridges where the freezer is on the top, I've seen the evaporator coils (which often incorporate "fins" like those on a car radiator, turn into a solid block of ice.
25823064-nzcmabjorfygbev20le00e4d-4-1.jpg Also check for dust collecting on the condenser coils on the outside of the fridge. These dissipate heat drawn from inside the fridge and take it outside the fridge. These are often located on the back of the fridge or underneath the fridge. Dust and fluff act as insulation and degrade their ability to work properly.
Obviously, to repair the fridge, you should relocate the contents of your unit until you can repair the fridge. Fixing your fridge will take at least a few hours even if you can get your hands on repair parts quickly. This will involve unplugging the unit and locating the items I've referred to. Either allow the accumulated ice to melt naturally or GENTLY speed up the process with a hair dryer or heat gun. Do not use any force removing the accumulated ice and frost, you could easily damage the coils and make things much worse than they already are. Even to the point of making the unit uneconomical to repair.
Without your posting a make, model, type of freezer/fridge arrangement or other details, it is difficult to assist you further. Part placement and component locations vary greatly in this appliance.
Aug 15, 2015 | Refrigerators
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Freezer fan motor is working but the coils are not getting cold what could the problem be?
Hi, Seems, your compressor does not work. Please check your thermostat setting and bring it a bit colder and observe your appliance.
Nov 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge not cold enough and frost buildup in the
Your problem is probably one of the following:
* defrost thermostat
* defrost heater(s)
Contact an appliance service company.
Feb 16, 2010 | Frigidaire Freezers
My frigidaire frc150ff fridge will not get cold
Completely defrost the fridge freezer, over 24 hours and switch back on, most times it will work properly again as this may need to be done on a yearly basis.
Sep 15, 2009 | Frigidaire Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Fridge & Freezer not getting cold enough
Welshons, Take a look at the picture Im posting. Did your evaporator look like it? If so your system may be restricted. This is a pretty common problem in Frigidaire top mounts. The good news is that it would be covered under warranty if it is not over 5 years old. As long as your condensor fan is running and the condensor is clean, evaporator not frosted up and evap fan running. I would think that you have a weak compressor or a restriction. Catriver...post back.
Oct 20, 2006 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
