Akai ap-m7 user manual
Akai AP-M7 serial number 81250-10616
  • 69 Answers
SOURCE: have akai ap-b110 turntable needs belt. Can you
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Posted on Aug 07, 2009
lesliemurphy
  • 69 Answers
SOURCE: Looking for replacement stylus RS-10 for Akai turn table AP-M10
go to this site?
http://www.needledoctor.com/Online-Store/Turntable
they may have it in stock or a suitable replacement? good luck
Posted on Sep 15, 2009
  • 74 Answers
SOURCE: how to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Posted on Oct 06, 2009
lesliemurphy
  • 69 Answers
SOURCE: I have a Akai AP-005 turntable. I need a new belt
email this company with your details and they may have the right belt for your deck?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
SOURCE: my akai ap 206c direct drive player has just
I have a 206 and a 207 both had dirty pots the speed controllers had to be pryed apart sprayed with cleaner they now work great.I hope this helps.
Posted on May 17, 2010
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Where can i find an owners manual for akai ap-l45 ?
First thing to do is contact the manufacturer {Akai}. Next thing is post your question on social media {Facebook, Youtube, etc.} You can also try posting the problem you are having - maybe someone else had it and has a fix for you.
Jan 21, 2015 | Audio Players & Recorders
I have a linear tracking Akai AP M313 turntable without a stylus connected. I have bought the correct part number stylus for it but can't see how it fits. Can you help?
You need to define the cartridge make and model for us to be specific; and read the manual(s) or sheet that came with the stylus. They typically slide in the direction opposite that which the old one came out. I'm sure if you look at the inner surface of the stylus it will have guides suggesting the way it is inserted.
Apr 09, 2011 | Akai Stylus Needle Apx1c M313w M452 (cd)...
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
How to remove platter from AKAI AP-B110 turntable
Mar 24, 2009 | Audio Players & Recorders
Need manual
Hi Greg
Unfortunatly, ongoing support for Akai died when the company did about 7-8 years ago. They stopped making non commercial product. So there is next to no on line support from them. What do you need to know about the turn table.. perhaps I can help.
regards
robotek
Nov 11, 2007 | Audio Players & Recorders
215 people viewed this question
 Grubhead
Grubhead
