How to reset sharp copier ar-m355 after developer changed
SOURCE: Sharp Copier Service Code
p,interrupt,clear,interrupt,enter#14, hit start,hit execute,hit clear all
Posted on Mar 05, 2008
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
  • 153 Answers
SOURCE: Sharp AR-156 Developer light stays on.but the
in service mode
Posted on Sep 28, 2009
  • 257 Answers
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Posted on Dec 01, 2009
How do i fix the error code f2-00 in AR-M351N copier
HI,
I assume you ran 25-02 when you changed the dev?, if not you will have to replace it again.
Check to make sure you have drive to the dev box, slide out dev box and rub your finger along mag roll and run it up, remove again and see if the dev has returned.
If it is a high mileage machine, you can get problems with the dev drive, the box itself or the toner sensor.
Cheers
Andy
Jan 24, 2015 | Sharp Toner Digital Copiers Ar M355 M351...
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M355 copier with AR-EF3 adf
With what you described it sound like the paper out sensor is not working properly, might be bad or broke. Hope that Helps... Lbcoaster
Jun 27, 2008 | Sharp Office Equipment & Supplies
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
56 people viewed this question
k24674
jasbo
jasbo
