Question about Yamaha DV-C6660 Multi-disc DVD Player
Unit will not trun on
Power source correct was working when was turned off manualy
    Guru:
  • 513 Answers
Try this: Unplug the unit for 10 seconds, plug back in and press power.
If this does not work, it usually means the internal power supply has failed. It is common for DVDs to fail after they have plugged in a long time, then not start up when reconnected to power. If the unit has enough value, replacing parts called capacitors in the power supply usually corrects the problem. You need a reputable service person.
Posted on Feb 22, 2012
Why wont my lexmark 3300 printer not turn on?
Have you confirmed that the power source is pumping out the correct voltage/amps with a voltmeter, too? I'm assuming you meant that you verified the power outlet works?
Jan 02, 2015 | Lexmark International Lexmark 3300 Series
Hit a RESET button, now I have NO T.V.
first select input source if menu visible then search channel manualy also store manualy auto function wil not work
Mar 10, 2014 | Generic Hiteker E32V7 32 in. LCD HDTV
Has power but will not turn on.
Check power source to make sure it is correct voltage/amps
Dec 09, 2013 | Uniden Bc340crs Bearcat 100 Channel Police...
Monitor "check signal cable" message
Try first, select input source manualy.
Sometimes, it automatically trys to detect DVI source first.
Jun 19, 2013 | Samsung Computers & Internet
I am trying to hook up my ps3 but it says change resolution source
make sure everything is plugged in correctly. also make sure that the input/source of your tv is correct. If all these don't work, then: 1. unplug both the tv and the ps3 2. plug them both back in 3. turn the tv on first make sure it is on the right hdmi source. 4. turn the ps3 on by holding down the power button for about 10 seconds until it beeps.
the ps3 start screen should show up now.
May 28, 2011 | Philips 32PFL3505D 32 in LCD TV
I cant play my ps3 on my sanyo tv
May 27, 2011 | Televison & Video
Power light on nothing else
1.Power cycle the TV for a minute. Unplug it from power source then turn it on. 2.If it doesn't work, bypass any surge protector and plug directly to the wall socket. 3.Check if your power requirements is set correctly. 4. Try pressing the input button or source on remote control or TV panel. 5. Call service technician to check the TV.
Jan 25, 2011 | Televison & Video
Logitech x-230 9 pin problem . i need to manualy insert wires into pin holes.. So can anyone tell me the color and pin hole nunber to put right wire into
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
May 15, 2010 | Logitech X-230 Computer Speakers
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Yamaha DV-C6660 Multi-disc DVD Player Logo
70 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
