Question about Ruud Heating & Cooling
FA4CNC036 FILTER SIZE - Ruud Heating & Cooling
2 Suggested Answers
  • 125 Answers
SOURCE: Need Size for my filter,
I assume the filter goes in at the bottom of the air handler. Carrier, in their infinite wisdom, uses the oddest sizes of any units. Use a tape measure and measure the depth and width of the opening.
It may be something like 19-5/8x21. You can't buy these off the shelf at home supply stores.
You will have to find a heating and air supply store to get them.
Hope this helps.
Posted on Sep 05, 2011
What size of sand filter hayward s711
711 is the style of valve head and goes onto many different sizes of filter body. there is usually a tag on the filter body to indicate the size as well as how much sand to use for that filter. if that tag is missing, measure the diameter of the filter body as, again, that will let you find the information you need
Apr 30, 2014 | Hayward SAND FILTER, PRO SERIES
Where does the washer go in the tetra wisper x30 filter go
A size and description of the washer could help. If it is the size of the intake tube then it is for the intake tube. If it is the size of the filter then it is for the filter etc etc.
Nov 12, 2013 | Tetra Whisper Ex45 Aquarium Filter 30-45...
What Size PVC piping for Hayward Sand Filter
what size is you pool plumbing and what size is filter inlet and outlet
Apr 17, 2012 | Hayward SAND FILTER, PRO SERIES
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Need Size for my filter, unit Carrier Model FA4CNC036
Hope this helps.
Sep 03, 2011 | Heating & Cooling
Need to know the filter size
The filter size should be on the filter you remove from the return air duct on a split system. If you can see the old filter take it out. The size will be on the side that is probably obstructed by the sides of the grill holding it in place.
Aug 03, 2011 | Heating & Cooling
Safety switch turns off AC
Locate the drain pipe from the air handler on the outside of the house. It is probably near the condenser(outside unit).
Use a shop vac to vacuum out the drain line.
Apr 27, 2010 | Carrier 38CKC036 Air Conditioner
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Lens filter size.
The filter size for the FZ20 is 72mm.
May 19, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Heating & Cooling Logo
79 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
