Question about Kitchen Ranges
Why is my baby belling cooker keeps tripping out in main breaker.when i heatup
When i turn on the cooker and it starts heating few sec later it tripps out
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
latoss101
  • 47 Answers
SOURCE: My Belling Fusion Cooker main
sounds like you have a internal fault it will be best to get repaired by engineer. ok
many thanks lee.
Posted on Jan 03, 2009
  • 131 Answers
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: main oven won't work
On ours you have to use the the timer controls; press the button with a hand symbol and the one next to it with a "-" symbol at the same time. Try a combination of the buttons on yours if this doesn't work. Weird, and took me months to figure!
Posted on Feb 15, 2009
  • 389 Answers
SOURCE: keeps tripping the main breaker on the electrics
Sorry if this is stating the obvious, but this is a sign of an electrical fault. Specifically, what trips the main breaker is leakage to earth (ground). You need a qualified electrician.
Posted on Feb 18, 2009
My Creda Reflection double oven keeps tripping the oven fuse when I turn it on? It doesn't trip straight away, it works for a minute or so and then trips the fuse. Any ideas?
call an electrician to check the circuit insulation for shorts
could be vermin cooked across electrical terminals , failing insulation, grease /fat across terminals
dead shorts trip the breaker immediately, ground leakage problems take a little longer
May 07, 2017 | Creda Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
My air compress quit one day-tripped dedicated 20A breaker,25' of 10 ga wire thats worked fine for 9 yrs. Compr. is 9 yrs old -looks NEW gets little useage (20 hrs per year). Have taken apart mechanically;...
An ohm check doesn't tell you much about electrolytic capacitors except that they aren't shorted. One is a run capacitor (usually low uFd value) and the other is a start capacitor (large uFd). If either dried up, the power consumption should be reduced. Look at the cases of these units--they should not be bulged or leaking electrolyte. Check the rotation of the motor shaft by hand--it should spin freely. A worn out or seized bearing would produce these symptoms. Smell the motor to see if it has a burned odor. It's possible that the internal wiring has shorted. The 20 Amp circuit breaker could have failed--try moving the wiring to a similar breaker for a test. Hope some of this helps!
Jan 17, 2011 | Garden
My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Dec 30, 2009 | Belling Ovens
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Oct 27, 2007 | Bunn RL Coffee Maker
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
