Question about Whirlpool Duet GHW9150P Front Load Washer
Disassemble Whirlpool duet
A tenant washes something that has left a grease residue in my washer. U have used a non-solvent based de-greaser (Simple Green) and ran several empty loads with just the degreaser and the residue has decreased but not been eliminated. Can I disassemble the tub to where I can wipe it clean with acetone to remove the grease and not damage the rubber components?
  • 5,911 Answers
Yes, but it is quite involved if you're up to the challenge. The following link explains the step-by-step details involved in removing the wash tub and spin basket:
http://www.fixya.com/support/r752855-replacing_rear_tub_bearing
I know this link is for replacing the rear tub bearing. The process is still the same, however, as it involves removing the entire tub shell assembly. There are no special tools required, but an electric screwdriver with socket attachments will make the process of separating the tub shell halves go much faster. I would also recommend that you order and replace the tub gasket if you are going to separate the tub halves. You can find a replacement gasket at searspartsdirect.com. Just type in your model number and look under the "Tub and Basket" heading for item number 10 (part #8181673). Other items to consider (but not mandatory) are the shocks for the tub (item number 23 - part #8182703). The shocks twist to release and they can sometimes break when you attempt to remove them. I hope you find this information helpful. If you have any questions, please let me know.
Posted on Oct 27, 2008
My downdraft vent no longer removes cooking fumes and smells for days after cooking. We have changed the screens, but still have residue coming from the vent inside the cabinet. Does this vent need to
Remove the motor together with the blower wheel, go to the local self service car-wash and use the engine de-greaser cycle (if not available, buy a can at the auto supply, spray the fan blade and let sit for a while) and get all the grease of the fan blades. make sure the fan blades are cleaned thoroughly. the fan will now ran quietly and will remove all the grease away. in the future, clean the filters often.
Jan 06, 2014 | Kitchen Ranges
Whats f21 mean?? a new belt??
Hello, Welcome to FixYa.
Based on your post I understand you have a F21 problem with a Whirlpool Duet washer, that indicates the F21 error means an excessive drain time, the belt is a non-factor.
If you follow the link to my solution to this error you should be fixed up in no time.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry.
Regards,
Macmarkus :)
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer stains my clothes. it looks like grease stains on delicate fabrics. plse advise. I checked many times and dont know where it is coming from. agnes
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Viking 6440, sticks in reverse. Hair dryer on high temp. fixes it until it cools off. How can I clean the old grease out and add new grease, myself? Repair is 425.00 at the shop.
You need to purchase a de-greaser spray to clean out the old grease. Im sorry but Im not an expert at this type of machine, but most of the inner workings are similar to all brands. You need to remove the top to expose the crankshaft device that is inside, and spray with a de-greaser. If you know the area where it sticks try that area first. A common de greaser is actually WD40. It lubricates and de greases, you could try this, if available in your area. You may have to use a lithium based grease for that machine I cannot say for certain. I do however have a link to the Husqvarna help site if that will help.. http://www.husqvarnaviking.com/us/2821_3079.htm
Mar 16, 2010 | Husqvarna Viking 1
Grease or rust ?? My front loading whirlpool duet washer is
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Grease on my freshly washed cloths
This sounds like a seal problem in the base of the agitator. This seal is what keeps the water inside the machine and the grease out of the wash basin. It is not something that should be attempted to repair if you are not mechanically inclined.
To get the grease out of your clothes, use an engine de-greaser which can be bought from any automotive parts store. You just spray the de-greaser on the area where the grease is located and rub it in by hand. You will need to use lots of soap to remove the de-greaser from your clothes, and might have to wash the item twice, to get rid of the de-greaser smell from the clothes.
Note, the de-greaser will break down all oil stains and grease stains, and is an oil by-product. This has worked for me on many occasions, but I have only used it on denim jeans and cotton shirts, with excellent results.
Aug 14, 2009 | Fisher Washing Machines
Waxy residue throughout interior of clothes dryer,
GOOF OFF or hairspray ,allow to air out before use.
Jun 18, 2009 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
1,190 people viewed this question
Dan Webster
Dan Webster
Sal De
