Question about Sony KV-ES34M61 34" TV
7 blink my tv has a fault led 7times blink no raster and no sound
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
Sony kv36xbr800 service code blinks 7times after tv shuts itself off
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 13, 2015 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Panasonicflatscree I have a panasonic flat screen tv model tc50c2 Try to turn on red light blinks 7times until it is un plugged
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 27, 2014 | Televison & Video
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
Sont tv model#kv-32hs420
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Check this link for more details.http://electronicshelponline.blogspot.com/ Pull up older posts. Blinking codes to Sony TVs are given in detail.
Jun 05, 2013 | Televison & Video
Hi, my panasonic tv power light flashes green, then it turns to orange flashes 7times then stops and starts again=orange and repeats itself by flashing orange 7times over and over , Again This is the power...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 23, 2017 | Panasonic PT-56LCX66 Television
I got a problem in TV. TV starts and shutdown immediately, while from sound its looks like that raster is going up but no picture, no sound. Red light is blinking. This happens only when i power off the tv...
Hi Sikandar,
Let me know how many times red led blinks as there would be an interval of 3 seconds so count blinks from pause to pause.
Is it Sony AR25M61 model or any other?
Above info will help to diagnose problem.
Thanks.
Nov 13, 2009 | Sony KV-AR25M61 TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony KV-ES34M61 34" TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
