Question about Pioneer PD-R609 CD Recorder
Need unlock din lock - Pioneer PD-R609 CD Recorder
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
My samsung c3053 din't accept any sim and ask for password,what i do to fix the problem?
if didnt accept any password it means your phone is locked. you need to unlock it to insert other simcard. you can unlocking your phone through codes. you can get the codes from your service provider itself with whom your phone is locked.else you can get it from other online providers like Classicunlocking.com
Nov 25, 2011 | Cell Phones
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
Ce cod de blcare are din fabrica un nokia E71
I think You need Unlock code...If you need Unlock code means You can reach here
http://www.prounlocking.com/nokia-e71/rs8wp9/ check code for Your Network Currently locked and Unlock the Mobile... after getting the Code...
Dec 17, 2010 | Nokia E71 Smartphone
Aftermarket double din install having problems with int. dash lights,locks
I had soved my problem... That was stupid.. The cause is that I tried to connect the (illumination +) and the (illumination -) wires togetter on the dimmer wire of my double din unit. That make a short cut and blow the litening fuse (fuse 13 on passenger side fuse panel). I replaced correctly the wiring, keeping the (illumination +) wire unused. That solve my problem but, however I get back my dash illumination, I can't adjust the lightning level... I thing I have a problem with the level switch.. It don't matter to me but if you get the same problem and solve it, please tell me your solution.
Regards
jerome
Jun 02, 2009 | 2001 Acura 3.2CL
Won't record...says din lock
I'd say you have the digital input selected. The player does not see a digital signal and gives such message.
Select the analog input and you should be able to record.
Hope this helps.
Jan 13, 2009 | Sony MDS-JE470 Mini Disc Player
I nedd ddx8017 bypass code
I need a unlock code for the kenwood ddx8017 dvd player the unit has locked me out
Aug 20, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Pioneer PD-R609 CD Recorder Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
