Question about Echo Garden
How do you adjust the carb on an echo sch212 hedge trimmer?
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
cactus bob
  • 267 Answers
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
this is the same attachment as mantas tillers use to make there tiller motor into a hedge trimmer try there website for a download ................if this answer helped please rate 3 or 4 stars this will keep me in the paid answer department
Posted on Apr 02, 2009
lemmingleejn
  • 173 Answers
SOURCE: Echo SHC-212 hedge trimmer starts and runs briefly
If it has not had a service recently, it's probably due by now.
Just take out the spark plug, and if it's black, or 'coked' up, just show it a wire brush.
Also, remove the air filter, and if you have one, show that, a compressor. (or alternatively, just bang it about a bit, till all the loose debris, and collective build-up, are removed.
Afterwards, (if that doesn't solve the problem),
you can adjust the timing, quite simply, by closing, or opening, the gap on the plug.
Or you can open or close the space between the contact, and the magneto.
Both can be very 'effective' means of adjusting the timing.
If problems still persist,
you know who to ask.
P.s. and don't forget to give the thumbs up ;)
Posted on Jul 31, 2009
  • 202 Answers
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Posted on Oct 23, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
Bogs down after warming up
check exhaust port first. then carb adjustments, then either crankshaft seals or carb needs replaced... You cannot adjust carb, it has to go to a certified center for this procedure... Thank the EPA for this B.S. and no you cannot by the adjustment tools on Ebay.
Nov 26, 2013 | Echo Garden
Echo hsc 225 hedge trimmer throttle sticks
I would suspect a defective throttle valve ( carb ) try this, three screws on top ( by throttle valve ) loosen them slightly and see if this frees up. If not find a dealer and get a new carb. You now know what damages ethanol causes.
Nov 12, 2013 | Echo SHC-225S Hedge Trimmers
My Echo SHC-212 will start and slow idle but when I give it gas it boggs and stalls. I've changed the spark plug and I'm using the proper mix. Any suggestions? I was thinking of trying to clean the carb...
The prior posters must be from the Briggs & Stratton era :0] This is an EPA carb. You can only adjust the idle speed. The Echo SHC-212 uses the Zama RB-K75 carb.
My SHC-212 had the same bogg/stall symptoms. I had to disassemble and clean the carb to get rid of it. There is an internal filter screen that sometimes clogs. I soak and use compressed air to blow out all orifices. But the real problem is leaving ethanol gas in the carb during storage. It warps the delicate gaskets/valves. So buy Zama rebuild kit.
Dec 24, 2010 | Echo Zama Carb Kit For Shc212 Hedge...
Carb needs to be adjusted, what are the settings for the carb?
I suggest you turn the jets 1-1/4 turns out and start it up and you can fine tune it from there.
Dec 06, 2010 | Echo 24 In Double Reciprocating Double...
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
Cleaned carb on echo headge trimmer how do i redo
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
Oct 24, 2009 | Echo Garden
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
