Question about Xerox Phaser 8560MFP Laser Printer
Document feeder disconnected on a xerox phaser 8560mfp/8860mfp
SOURCE: Printing Black & White
sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
Posted on Aug 19, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560MFP/N System error
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Posted on Jul 31, 2009
  • 26 Answers
SOURCE: our xerox printer phaser 8560MFP does not work and
This error code specifically means: "The media path motor stalled while moving the cap/wipe down."
In English, there is a component inside your machine that is either moving too slow or is obstructed by something.
This can either be very serious or can be surprisingly simple.
If I were you, this is what I would do:
1) Make sure the waste tray is empty.
2) Make sure there are no paper jams or paper scraps anywhere.
3) Check the preheater and make sure there are no obstructions.
4) Replace the mainten
ance kit. See link below.
*This ensures that the printhead is properly lubed and is not dragging behind or stalling
5) If it still does not work, bring it to your nearest Xerox Partner.
If the top suggestions did not work, the problem must be very serious. Your average person cannot fix the problem themselves with any motors or gear packs.
Good luck. Please rate my response or post a comment on your original question to allow me to further assist you.
Maint. Kit:
http://www.office.xerox.com/product-resources/108R00675/enus.html
Find a Partner:
http://www.office.xerox.com/cgi-bin/resloc.pl?what=Service
Posted on Aug 18, 2009
  • 526 Answers
SOURCE: XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Posted on Dec 13, 2009
Phaser 8560mfp document feeder jam not clearing
try cleaning the rubbers that turn the paper it should work try cleaning it with rubbing alcohol or nail polish
Sep 24, 2013 | Xerox Phaser 8560DN Laser Printer
My Xerox 8860 scans a blank page before each document.
One possible solution.
Check to see if you are set to duplex copying as default, this would cause it to print a blank reverse page of any single sided document.
Jan 05, 2011 | Xerox Phaser 8860MFP/D - Multifunction -...
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
Dec 27, 2010 | Xerox Phaser 8560MFP Printer
Xerox 8860mfp how do I reset the Maintenance kit counter until a new one arrives
It cannot be reset at all.
Xerox makes you buy a new one, either 108R00675 or 108R00676
Whit
Item, Inc.
Dec 14, 2009 | Xerox Phaser 8560MFP Laser Printer
Dec 12, 2009 | Xerox Phaser 8560MFP Laser Printer
Aug 19, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
422 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
