Question about Probasics Digit-Ox Finger Pulse Oximeter
Replacing batteries I have had directions from Smith Medical as to how to open the battery casing and replace battery. The casing will NOT open. Low battery is indicated and I need to have an oximeter available. Should I just go buy another one of a different brand?
I need a battery replacement for this this unit (MO-H04CD EGET portable oxygen concentrator) but cant find it anywhere. Can anyone please help me?
having no idea as to the make,model you tie our fingers .some hide them under the back seat , buick in particular
Apr 20, 2016 | Oxygen Portable Oxygen System
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
What does RFA 1 battery low mean?
The battery in your keyless remote #1 for the vehicle is low and needs replacing.
May 24, 2010 | 2003 GMC Yukon
Internal battery is warning of low charge
No, it's not difficult. Just open the case and locate on the motherboard a round (about 2cm diameter) battery, like the one at the electronic watches, a little bigger. Push the little metal holder to the side in order to set free the battery. With the old battery as a sample buy a new one from a shop at your area, it is cheap enough.
In case of a problem or clarification, don't hesitate to post.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 14, 2010 | Dell Dimension 8300 PC Desktop
How do I disassemble to replace battery?
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant).
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Nov 30, 2009 | Norelco ReflexPlus 6863 XL Electric Shaver
Having to reset date and time
Solution: Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution_a70.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids could damage the stomach or intestinal wall.
  1. Confirm that the camera is turned off.
  2. Open the terminal cover and use your finger nail to pull out the battery holder.
  3. Pull open the battery holder in the direction indicated by the arrow (1). Remove the battery by pulling it up in the direction indicated by the arrow (2).
  4. Insert a new battery with the ( ) side facing up.
  5. Replace the battery holder back and close the terminal cover.
  6. When the Date/Time menu appears, set the date and time.
note_icon_a70.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your country.
Dec 24, 2007 | Canon PowerShot A520 Digital Camera
Error message "Backup Battery Very Low"
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
Sep 14, 2005 | NEC MobilePro 900 Handheld
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Probasics Digit-Ox Finger Pulse Oximeter Logo
95 people viewed this question
Top Probasics Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
ray gallant
Are you a Probasics Health and Beauty Expert? Answer questions, earn points and help others
