Question about Ovens
It's for a Thermador MSC224 electric oven and the part is 14-39-030. Bosch made a replacement Part Number: AP2832670, but that also has been discontinued. Another Bosch part number is 415241, an
T's for a Thermador MSC224 electric oven and the part is 14-39-030. Bosch made a replacement Part Number: AP2832670, but that also has been discontinued. Another Bosch part number is 415241, and that also is discontinued. Can you provide any of those or some other replacement. The part is called a PULSER and it's function is to keep the oven being cleaned from going over about 1000 degrees.
  • 70 Answers
SOURCE: After cleaning the top half oven with a self-clean
usually it is the thermal cut off( TCO) ,a kind of themal fuse which goes out if the temp exceeds certain limit and cuts off the power to the elemnts.it is to protect the cavity from over heating.it needs to replaced or reset depending the model. u will need a tech to fix this.
Posted on Aug 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: The clock works but the oven does not heat up
Hello George, welcome to fixya.
The symptoms you describe are a common occurrence when the hi-limit has tripped. This typically occur's following a self clean cycle. The display will indicate the oven is indeed "on" but it will not heat do to the circuit being interrupted by the hi-limit ( which is what it was designed to do ).
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly. **Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...52bc5ab.jpg
Let me know if I can assist you further. If this solves your problem please rate the solution accordingly, if not let me know and I`ll try to guide you through other possible scenario`s.
Thanks for visiting "fixya" and good luck.
macmarkus :)
Posted on Jun 15, 2010
SOURCE: thermador oven parts
I have a Thermador oven where the inside window glass is broken. Are there any parts available for a
model #14-33-754
30 "?
kellythompson@frontiernet.net
Posted on Nov 22, 2010
KevinWhite
  • 1902 Answers
SOURCE: I need a replacement selector
Hello & Welcome to FixYa
You can buy it from here. Please get back to me if you have any other questions.
Kevin
Posted on Sep 13, 2011
KingDWS
  • 1606 Answers
SOURCE: I need a selector switch for an old electric
FixYa itself cannot supply parts. IF you have a confirmed source for the switch you should grab it. Unless a local appliance repair shop can supply it you may have to order from UPS. I would talk to them and confirm if they have the part or not. Usually when a part is discontinued it means it is no longer being produced or stocked. So if they have stock that is all there is available in their system. The older a appliance gets the smaller the variety of spare parts available. At the end they will only have parts that are guaranteed to need replacement or parts they never have sold ie dead stock.
Aside from local shops if you have any you can contact Thermador who are in California.
They will be able to tell you if they have the switch or which distributor or repair shop might have one.
Phone: 1-800-735-4328
24 Hour Call Center Access
Email: htb-questions@bshg.com
Address: BSH Home Appliance Corporation
Attn: Thermador Customer Support
5551 McFadden Avenue
Huntington Beach, CA, 92649
Posted on Sep 15, 2011
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Nov 28, 2011 | Thermador SC302T Electric Double Oven
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
I need a replacement selector switch for an electric oven. It it for an old Thermador electric oven (one cavity type wall oven). Model number: WO-18A
Kevin
Sep 13, 2011 | Thermador Ovens
Oven will not heat up broiler works. its a thermador rdss oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Looking for the repair & users manuals for my thermadore wall oven sc301tp
Hello cfrisz,
I am new to the fixya and I saw that you were looking for a manual. I hope that this information can help you find one if you still are looking.
At this web they have a similar users manual or if you type in model (if there is another number on oven) number maybe they'll have it.
http://outdoorcooking.manualsonline.com/search.html?q=Thermador+SC301tp&submit.x=25&submit.y=28
or here is the main website (you might have tried it already)
http://www.thermador.com
in the contact us section there is a form to fill out and maybe you can get one that way. I'm not sure on response time. Most company's do not mind giving people replacement manuals.
hope this helps
Mar 07, 2009 | Thermador C302U Electric Double Oven
Thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Jan 13, 2009 | Thermador C302U Electric Double Oven
Thermador oven timer doesn't repeatedly chime for 5 minutes anymo
I just fixed my timer! Press and hold the OFF button for 10 seconds (until you hear 1 chime). Thanks to David at Bosch/Thermador!
Nov 17, 2008 | Thermador SC302T Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
