Question about Netopia (4686-XL) Router (4686XL)
Need help to set up a VLAN on 4686-XL
I need to set up a VLAN on a Netopia 4686-XL router. 1 leg to go to the internet for an internal NATTED private network (say 192.168.9.0) and one to a wireless AP that will use a separate subnet: 192.168.99.0) and needs DHCP for that subnet. The two subnets should not be able to see each other. Or I need the location of the documentation to guide me through the process.... Thanks
cnavarro
  • 2460 Answers
SOURCE: Programming Netopia 3347 wireless router
You mean what program? Telnet. Here's the quick setup. If it's already been installed and password protected, you'll need to grab the installation guide somewhere else.
http://www.netopia.com/support/hardware/manuals/3347W-ENT_qsg.pdf
Carl
Posted on Aug 29, 2008
  • 53 Answers
SOURCE: vpn
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
Posted on Nov 06, 2008
dante777
  • 623 Answers
SOURCE: need set up instrutions for netopia 3347w router
You find setup instructions here or can download the complete manual here.
Good luck and enjoy!
Posted on Dec 28, 2008
SOURCE: How do you hook up a Netopia 2247NWG-VGx Wireless
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the innternet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any querry pls feel free to get in touch.. good luck
Posted on Sep 03, 2009
  • 93 Answers
SOURCE: my network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Posted on Mar 09, 2010
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Conect webcams on a local network to a website
I presume that you mean "from a web site" that the web site is hosted somewhere out on the greater internet.... The problem that you are encountering is probably related to NAT (Network address translation). The "In" side of a router, is typically a "private network" there are pre-assigned number groups for these - a common one is in the 192.168.x.x range. Problem is that the "outside" of your Netopia router will be dependent on your ISP< and unless you are paying them extra for a static IP address, is likely to change every time you reboot - or sometimes they bump them every 24 hours. So, first thing is get a dynamic DNS Entry - www.dyndns.org is one supplier - I think you can get one address for free from them, pay for more.. YOu set up something like CMVideo.dynsdns.org on their site, and set up dyndns support in the netopia router... Then you want to open the specific port on your router, to go to the internal IP Address of your camera. (YOu mention Multiple Cameras - depends on the Camera you may have to go for multiple dyndns (one for each...) ).
I am a little confused/concerned about the second router "tier" - if you have the Belkin configure as an Access Point only, all good, if you are trying to run it as a router behind a router, it will probably never work - double nat-ting" is a no no with most consumer Routers. Simple solution is to tap from Netopia lan side to Belkin Lan side (rather than Belkin Wan Side)
Nov 14, 2013 | Netopia Computers & Internet
How to change my router's MAC address Netopia 3397G
Using a router is a great way to create a home or office network without having to spend a lot of money.
As long as you have a broadband Internet connection through an Internet service provider, you can use a router to get all of the computers in your home or office connected.
If you have chosen Netopia as your router brand of choice, you will have to configure it to make your network operable.
Power on your Netopia router, broadband modem and computer.
Open your Internet browser.
Type the router IP address, 192.168.1.254, into the address bar. Hit "Enter" on your keyboard. Log into your Netopia router with the username and password assigned to you by your Internet service provider.
Select "Expert Mode."
After entering expert mode, you will see a menu bar at the top of the configuration window.
Click on the "Home" tab. Many Internet service providers will ship your Netopia router to you preconfigured.
If it is preconfigured all of the fields, such as IP address, subnet mask and default gateway will already be populated. If the fields are not populated, proceed to the next step.
Click on the "Configure" tab. Select "WAN." Select "ATM." Enter the "VPI" and "VCI" numbers provided by your Internet service provider.
Choose your encapsulation option.
For example, "Routed IP," "PPPOE," etc... Click "Submit."
Select "WAN" on the left side of your configuration window.
Choose the "VCC1" option. Select the option to "Enable Interface."
If you do not have your own IP address, choose the option to "Obtain an IP Address Automatically."
If you do have your own IP address, uncheck the automatic IP address box.
Type in your IP address if you have your own.
Enter your subnet mask.
This information can be obtained from your Internet service provider.
Select the "NAT" option if you are using your own private IP address for your network connection. Click on "Submit."
Ensure that there is a check in the "Gateway Option" box and "IP Address" is selected as the "Interface Type."
Type in your "Default Gateway" address.
This can be obtained from your Internet service provider.
Click "Submit."
Select the "Configure" tab at the top of your window. Select "LAN."
Select "Enable Interface."
Type in the IP address for your router and subnet mask. Click "Submit."
Click on the yellow caution symbol on the top right hand side of your window to save all configuration changes.
Click on "Save."
Restart your computer for the changes to become effective.
http://www.netopia.com/support/hardware/technotes/CQG_121.html
May 10, 2013 | Netopia Computers & Internet
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Setting up an hp 7102dl router
You need a switch.
Refer to this for more info:
http://ask-leo.com/whats_the_difference_between_a_hub_a_switch_and_a_router.html
Not spam.
Apr 08, 2009 | HP Computers & Internet
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Netopia (4686-XL) Router (4686XL) Logo
76 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
