Question about Dell Computers & Internet
Monitor says no signal and will not run a dvd
    Problem Solver:
  • 6 Answers
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Posted on Feb 21, 2012
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
Powers up screen lights up with vertical lines of different colors. NO desktop. DVD indicator lit up on keyboard along with Play, Rev and FF indictors, put a movie in and it wont play that either the drive...
Most likely you have had an lcd panel failure. The only way to tell for sure is either hook the laptop up to a tv or an external monitor, if the video chip is good it will send the signal to the external monitor and you can run the computer that way. If you do get a signal on the external, then you need to change out the lcd panel. As far as the dvd, you probably just cannot see that everything is working because the panel has failed.
Jan 06, 2010 | HP Pavilion dv9000z Notebook
No Signal on DVD to Samsung 2333HD Monitor/TV
I had the same problem connecting the monitor to my Philips DVD player. After a couple days trying to determine if the monitor or cable was bad, I went to the Philips user manual and found that the Video Output setting had to be specifically changed to YPbPr/Component (which I needed). Apparently the player sends the signal in only one format at a time. Hope this helps.
Jun 10, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Can get tv channels/signal through the monitor
try changing the cable connecting the tv to dvd it could be faulty
Apr 30, 2009 | Televison & Video
Video Inputs for Denon AVR 589
manual is here: http://www.usa.denon.com/AVR-589-OM-E_006.pdf
Note on page 11 says "because video signals are out put from the AVR-589's monitor output terminal IN THE SAME FORMAT AS THE VIDEO SIGNALS, THE MONITOR OUTPUT TERMINAL SHOULD BE THE SAME TYPE AS THE TERMINAL USED FOR INPUT."
You cannot mix the HDMI with the others. You must therefore use the same on DVD and Cable box.
Best Regards and happy new year!
Charles
Jan 05, 2009 | Audio Players & Recorders
I have just set up new desktop Acer. Error message: No input signal.
check the website for drivers. But it seems to me that there is another problem most computer boot up no matter what screen is hook up. have you tried any other monitors ? If you have and the work im not sure what your issue is but i would say that most likely if another monitor works that it is the monitor but if none of them work it is a graphic card issue. If you could let me know what you are running and i can help more i.e what window's and what type of graphics card you are using
Oct 26, 2008 | Acer Aspireā„¢ T180 PC Desktop
MONITOR CONVERTER
It would require two seperate components. The first is the cable, the second is the signal converter. The cable can be found at any A/V store and the converter can be found at:
www.ramelectronics.net
MSI VGA DB15 to S-Video Convertor Cable
Specifications
Mfr Part Number: MSI-SVIDEO
Ram Electronics
Video to VGA Converter, GVM2000
$89.00
Convert your Composite Video or S-Video Signal into VGA (RGB/HV). This allows you to use a computer monitor as a display for your Standard Definition Video Source - DVD, Game System, VCR, etc.
Oct 15, 2008 | Computers & Internet
Yamaha RX-V800 Composite Video Signal Problem
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
Feb 09, 2008 | Yamaha RX-V800 Receiver
Computers & Internet Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
