Question about Coby PC Netbook 1ea
My computer software crashed - Coby PC Netbook 1ea
  • Rich lunness Feb 21, 2012
    What Software was it and what exactly were you doing when it crashed?  How many other windows did you have open?  When it crashed did it just lockup or did the window shut down?
Google chrome keeps crashing not sure why
You need to check out all these:
1. Check for Conflicting Software:
- Some third-party software can cause Google Chrome to crash. When this happens, you'll see the message "Whoa! Google Chrome has crashed. It's possible that you have malware that can cause Google Chrome to crash.
- Google Chrome has a hidden page that will tell you if any software on your system is known to conflict with Google Chrome. To access it, type chrome://conflicts into Chrome's address bar and press Enter.
- You can try to fix these crashes by updating, disabling, or uninstalling any conflicting third-party software listed in "about:conflicts" on your computer. Also, take a look at Google Chrome's known issues for specific solutions to resolve crashes caused by some software.
2. Scan for Malware
- This includes malware and network-related software that interferes with Google Chrome. Malware can also interfere with Google Chrome and cause it to crash.
- You can try using Malwarebytes, or other anti-virus software to scan for and remove malware or you can also try searching the web for information related to any conflicting modules listed on the chrome://conflicts page (Windows only), to see if there are other steps you can take to remove malware.
- Many crashes are caused by malware. If you're experiencing frequent crashes, try scanning your computer with antivirus software.
3. Solve Flash Crashes
- We have found that the Flash plugin Chrome includes can cause it to crash in some cases. If you are seeing regular Shockwave Flash crashes, you may want to try disabling the internal Flash plugin and using the standard Flash plugin in Google Chrome.
4. Switch to a New Profile
- Chrome crashes may be caused by a corrupted profile. You can test this by creating a new profile from Chrome's Settings screen. Open the Settings page from Chrome's menu and click Add new user under Users.
- Change to the new profile after creating it and see if the crashes continue to occur. You can sign into Chrome with your Google account to sync the data from your old profile. However, Google recommends you don't copy any files from the old profile folder by hand - they may be corrupted and causing the problem.
5. Fix System File Problems
- Google recommends running the SFC.EXE /SCANNOW program to check for - and fix - problems with protected system files on your Windows system if you are encountering crashes. To do this, locate the Command Prompt in your Start menu (press the Windows key and type Command Prompt), right-click it, and select Run as Administrator.
- Type the following command in the Command Prompt window and press Enter:
SFC.EXE /SCANNOW
- Windows will scan your computer for problems with system files and fix any problems it finds.
6. Hardware issues
- It can also cause Chrome crashes. You may want to test your computer's RAM and ensure it isn't faulty.
· If still problem not solve, maybe you should try these simple steps:
1. Try restarting your computer first. It could be that the computer has just encountered a slight glitch on your system, which is causing things to not work properly.
2. Remove and Re-install the Google Chrome application. Doing this will allow your computer to read the files a lot better and faster, and also repair any damaged or corrupt files that have been causing the issue. To remove the Google Chrome application, first insure that you have another browser, such as IE or Firefox, click "Start, Control Panel, Add / Remove Programs," locate "Google Chrome" click UNINSTALL next to it. When the application loads, select "REMOVE" (not repair). Follow the uninstall process, and restart your PC. Problems uninstalling or re-installing Chrome indicate mal- or spy-ware, which must be dealt with.
3. Remove any extensions that you have on Google Chrome. Although they are a great way to personalize your Internet browsing experience, they are not so good for speed and functionality, as many can cause the application to crash. To remove any extensions follow these steps: Open up Google Chrome. In the address bar type chrome: //extensions. Click Uninstall, or Click Disable if you think you may use the add-on in the future. Restart your browser.
4. Disable plug-ins. Chrome can get bogged down with plugins that you aren't using, also. Type about: plugins into Chrome; it will redirect to chrome://plugins. Disable any that you aren't currently using.
Hopefully your Google Chrome crash problems are gone. Hope it works. Sharing is always caring.
Sep 25, 2013 | Google Chrome
Computer crashed and fix-it utilities 11 didn't reload fully. Need to enter product key and reinstall
I would recommend a top utility software, use intel partner software RegInOut to fix all your operating systems errors.
Dec 08, 2011 | Avanquest Fix-It Utilities 11 Professional...
APPCRASH error please help
When program files or files within your computer's registry have become corrupted, this can cause the programs to unexpectedly crash. When a program crashes, you will likely get an Appcrash error. The error message will say "Windows Media Player (or whichever program has crashed) has stopped working" and then list rows of technical information regarding the cause of the crash. Unless you are a computer programmer, you may never fully understand what caused your program crash, but that doesn't mean that you can't fix it.
Delete any new programs that you have downloaded. Often, the cause of corruption in a computer system are bad downloads that bring harmful files onto your computer. If you started to get the Appcrash error on your system after downloading a new program or software from the Internet, it's highly likely you have downloaded a bad product. Use the "Add/Remove Programs" feature in your "Control Panel" to get rid of the program immediately.
Uninstall the program that is crashing. It is possible to fix the program's corrupted files while the program is still installed, but to make sure that you clear the program files completely, it is safest to completely uninstall it from the system.
Run a full scan of your computer. Your computer should already have antivirus software installed that can scan for corrupted files and either fix them or delete them from your system. If you do not have antivirus software on your computer, that could be a big part of the problem. Purchase and install antivirus software as soon as possible. These are designed tor from outside threats. Once you have the antivirus program installed, open it and click "Scan Computer." The antivirus scan will isolate bad files and you will be given the option to remove them from your system.
  1. Reinstall the program that was crashing. Now that the corrupted files have all been removed, your program should run smoothly after reinstallation.
  2. Check for program incompatibility. If, after a thorough scan and cleaning of your computer and reinstallation of your program, the Appcrash errors continue, the program you are trying to use may not be compatible with your program. For instance, there are some DVD softwares, such as Media Now, that do not work correctly with Windows Vista. These lists can be easily found online. If this is the case, you will have to purchase a software program that is compatible with your OS
You should download a program such as RegCure and run it from time to time. If you are unable to download a copy let me know and I will give you a link on my web where you can download it.
Jan 16, 2010 | Microsoft Internet Explorer 7
My computer crashed, so I wiped it clean and started over. I down loaded the software but did not pull the card out first. Then I uninstalled the software, shut the computer down, removed the card, turned...
if your problem is your computer crashes due to wireless adapter card.. try turning off your pc and remove the card, then boot your pc.. and see if it still crashes
Oct 19, 2009 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Windows Vista crashes when I connect my Linksys wusb54g wireless adapter. It worked fine for about 3 months, then started crashing, now I can't have it connected, or it crashes instantly.
This is a software conflict of the linksys device to your system, so to correct this remove first the software from your computer and then after that restart the computer and then connect the adapter on different usb port , if still having the same problem i will suggest that you have the device replace.....
Oct 09, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Due to a virus I had to crash the computer. The
You will either need A) a new network card / some other method of getting online to get the drivers / software B) the original discs that came with the computer to restore from C) a phone call to dell support to request the software.
Jun 24, 2009 | Dell Ethernet Card Network Adapter
Have lost cd, computer crashed. no way to download
Here is Canon's download page for your model. You can download the software you need and all the other documents they have available.
May 21, 2009 | Canon PowerShot A640 Digital Camera
Computer crashed I nee to transfer my music from juke to computer
Download the desktop software from another PC and you can find the desktop software for your Samsung SCH-U470 on the manufacturer's website.
Once your have completed that step, set up your data transfer again, retrieving songs from your device back to your PC (like drag and drop).
I would recommend (since your computer has crashed) using another PC that you can trust, downloading and transferring. This may seem a little inconvenient, but it is your only option at this point.
Mar 19, 2009 | Samsung SCH-U470 Juke Cellular Phone
Antivirus 2008
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Some Tips for Dealing with Freezes and Crashes
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
Oct 18, 2008 | HP Compaq Presario v3000z Notebook
Computer Crashed
Please follow this link, choose your operating system and then download the link for the software on that page:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Z715
Thanks,
Lolita
Apr 08, 2008 | Lexmark Z715 InkJet Printer
Coby PC Netbook 1ea Logo
41 people viewed this question
Top Coby Computers & Internet Experts
shadowchb
Are you a Coby Computer and Internet Expert? Answer questions, earn points and help others
