Question about Neff U1421 Double circotherm Electric Oven
Thermostat or Heating Element?
The light is on, I've got power, the fan is working - the oven just wont heat up. How do I check if the Heating Element is recieving power to ensure it's not the Thermostat that's the problem?
  • 1 more comment
  • boatsnips Nov 15, 2007
    Oven appeared normal but not heating up - is it a Thermostat or Element problem.
    The simplest approach is to check the element first - this can be done leaving the unit in its built in housing and is relatively easy to do.
    Isolate power supplly, remove oven door (for cleaning), remove cover to fan and element - 6 screws. Element and fan exposed. Remove 3 element fixing screws. The element and connections can be drawn into the oven space.
    Disconnect the electrical connections - pull connectors off with care - and check the continuity of the element with a test meter also check the resistance between the element and the element fixing plate. The continuity resistance will be in the order of 25 ohms, The resistance to the fixing plate should be infinity. Any significant variation to this assume element faulty.
    If these test values are ok then the thermostat is suspect - a big job - call service engineer or write up the next solution!
  • Kendra123 Jan 01, 2008
    I think I hve the same problem, but searching for the right part to replace is rather daunting. What part number do I need for a new heating element for the U1241? thanks
  • Anonymous Mar 07, 2008
    I have a whirlpool electric range.the oven not heating,but the broiler works fine. I replace the bake element and thermostat,but the same problem is there .please,please help need oven
    Problem Solver:
  • 17 Answers
I work for a Appliance Parts compnay. I can look up part numbers for many differant appliance parts......You can contact me at www.appliancepartsonline.net info@appliancepartsonline.net
As far as the problem you are having is this: If it is not the Tstat or the Bake Element.....then perhaps it is the wires connected to the back element.........I have seen that problem before....check it out...i bet thats the solution!
Posted on Feb 16, 2009
I have a emachine laptop, it has power and the function, but after 15 minutes, it automatically shuts off.. what would i do? I'ved checked the software and other hardware parts they've kinda work.. but its very hot... what should i do?
Posted on Jun 12, 2008
    Problem Solver:
  • 6 Answers
Check out our element replacement guide at: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Feb 28, 2007
  • David Davis Sep 14, 2010
    Hi, I am a washing machine and electric oven repairs engineer and to find out if the problem you are having is the element or not simply do as mentioned by some one else above the continuity test and risistance test and you will have a fair idea whats going on.
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
Nov 29, 2011 | Smeg Ovens
Heating elements in fan oven not working
Nov 26, 2011 | Smeg Ovens
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Hi My power box just tripped and my oven turned off, prior to this happening it was working fine. I have a smegg oven model se378mfx5. It now wont heat up, it turns on ok but wont allow me to set the...
Feb 16, 2011 | Smeg Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
We have a fan oven, which started not heating, but fan and thermostat light still on! We thought it was the element! But now the oven is working very occasionally, still heating as normal! We can try to...
Elements don't heat intermittently - if the element is good it will heat up every time. If the element is blown / burnt-out it wont ever heat.
As your oven is heating sometimes but not others, this means the power supply to the element has an interruption somewhere. This could be caused by any of the following:
1. Loose connection in the wiring at the switch or the element
2. Faulty switch
3. Faulty thermostat.
4. Faulty oven timer
The thermostat is effectively just a heat-sensitive switch. By default it should be "closed" allowing power to the element. When the oven reaches the desired temperature, this switch opens, cutting power to the element until the oven cools enough for the switch to close and allow power to the element again.
Any of these four could be the cause of your fault. Loose connections can often by located visually, however testing a thermostat for correct operation and calibration is more complicated and ideally requires test equipment. The timer is the least likely cause, so I would concentrate on the others first.
Repairing your oven or any other electrical appliance can be dangerous and many repairs require specialist knowledge and/or electrical test equipment. Please bear this in mind before and when attempting any repair or consider having your appliance professionally inspected.
If you are intending to investigate this problem yourself, please ensure the power is disconnected at the wall/breaker first. Initially, I suggest that you visually check the connections at the element and the switch. You may find a wire at one of these locations that is partially broken or detached. Personally, I suspect your thermostat may be faulty.
Hope this helps.
Regards,
BElectric
Jan 01, 2011 | Ovens
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
The light and fan works but no heat comes on in oven.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Zanussi zbf 760 (9 yrs old now)
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Neff U1421 Double circotherm Electric Oven Logo
393 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
bobby1964
Level 1 Expert
Paul Carew
Are you a Neff Oven Expert? Answer questions, earn points and help others
