Question about HP cp1700 Color Inkjet Printer
Printer cyles fine but no printing appears
The printer had been setting for a while. I installed new cartridges and everything runs fine. However, the ink isn't getting to the paper. Is there a need / procedure to clean the transfer tubing and print head?
    Scholar:
  • 87 Answers
You said you installed new cartridges. Did you install new printheads? These are probably what are giving you the problem. The printheads are treated as a consumable on this printer. (#11 printheads)
Inkworks
866-381-0541
Posted on Nov 06, 2008
Installed new ink cartridges and does not print
check the driver settings for your printer. to find it, open the file you want to print. then choose file menu then print. on the print dialog box click the properties button located on the right side of the printer name. another window will appear.this is the settings for your printer. check the settings for the printer. choose color if black is selected on the print tab.
Feb 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer problems
HI,
First try to uninstall your priinter and then install it again after you change the catridges..Also make sure you dont have any other printers used parallely..pls try to add your printer through the control panel and then try it once again for taking colour print outs(make sure you select the proper settings in print tab)..your problem will be solved..thank you!!..
Jul 02, 2008 | Lexmark Z33 InkJet Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
New Brother won't print black
Take the printer back to where you got it from and exchane it for another one...
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Dell 924 all in one will not print magenta
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Ip90
just to be sure i'm going to ask this ??.. have you removed the little sticky clear film located on the new cartridge? not sure what kind it is but double check that.. if that's not the case, i would go into your printer properties and check thru your options and be sure you do not have some setting set to off that would affect your color.. if there is a default option, set it back to default settings, then reboot.. hope this helps.. d
Feb 21, 2008 | Office Equipment & Supplies
Will not print
Try using the 'clean cartridge' setting with your printer, this usually forces the ink through the installed cartridges.
Dec 11, 2007 | Dell 922 All-In-One InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
CANON BJC-85 Won't print black...
Turn on printer, press cartridge button, remove cartridge. On left side of remaining cradle, unsnap the cradle, lift up and remove. Take the cradle to your sink, wet a paper towel, and GENTLY wipe the long print head with the wet paper towel. Then run a small stream of clear cool water through the cradle, from the round pad that your cartridge rests on, until the pad looks ink-free. Dry everything with tissues and a hair dryer set on low, replace cradle in printer, replace cartridge, turn on printer, press Resume until it beeps three times, which runs the deep cleaning program, and after the procedure is finished, your printer will print as new.
Apr 14, 2007 | Canon BJC-85 InkJet Printer
HP cp1700 Color Inkjet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
