Copier CC is in the display and there is a red roller lit up. I just found this in a closet in my office, does it just need a new toner?
  • Mike S
    Mike S May 11, 2010
    What is the model and make of machine?
    Problem Solver:
  • 13 Answers
Im going to assume this is a Canon Copier, right? CC on canon stands for "copy Catridge". Which is the drum unit. Some models require a service tech to install but some are user installable. Either way I can send you the cartridge and assist you with installation if you provide the model number. Or you can call someone locally.
Posted on Oct 29, 2008
"SHARP COPIER AR-5618S, A NEW COPIER, TONER EMPTY, I REFILLED IT, BUT TRIANGLE RED LIGHT IS..."
Your problem is that you should not use refilled toner in you sharp copier but if you chose so you have to change also the chip in the end of the toner it will work fine
Jan 30, 2014 | Office Equipment & Supplies
Display malfunction
sir,
Open the front door, upper left small access cover remove and depress the trouble reset, if the code comes back replace the exposure lamp bright light under the big glass
try this site for starters Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 26, 2014 | Konica Minolta Copier Toner EP6001 CS Pro...
I changed the toner cartridge and now it won't print. The red round light on the control panel is lit. Now what?
If the round red light you describe is a circle of dots that indicates a developer change is due. This needs to be done by a technician but the machine should work fine without doing the developer change.
Nov 10, 2017 | Sharp AL 1631 Copier
WE HAVE MODEL #EP1031F. THE "READY" BUTTON DOES NOT LIGHT UP, COPIER DOES NOT PRINT. THERE IS ALSO AN ICON LIT UP BY THE COUNTER WINDOW THAT LOOKS LIKE A CROWN. IS THIS INDICATING IT NEEDS...
Have you installed a new toner??? It may take a few minutes for the copier to add enough toner to make a copy. It's been awhile scince I've worked on one... But I think if you turn it off and hold down the Clear/Stop botton when you turn it back on, it will make the copier add toner... It looks like the display i chashing a box in the display. Good Luck
Nov 01, 2010 | Minolta EP1031/1031F CS/PRO Copier
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
Feb 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
52 people viewed this question
jasbo
jasbo
