Question about Lands Phones
Logic L250 twin phone manual - Lands Phones
  • Peter Mcgimpsey Feb 21, 2012
    i need a manual please
  • yadayada
    yadayada Feb 21, 2012
    Who makes this?j
Canon fax L250 lcd contrast too light
hello, you can try adjusting the angle of the screen and use the function /menu button to find lcd brightness -- could not find anything in manuel
Aug 13, 2014 | Canon FAX-L250
How to i change ringtone on doro 530
After searching the net for a 'FREE' manual, I decided to just rely on my own instincts as a technician.
Scroll through the up and down buttons until you start to get a menu. Press 'OK' at the menu option you want and so on. It's fairly simple and intuitive. You'll stumble your way through til you get the logic behind it. Date and time are fairly simple.
Hope this helps.
J.
Dec 20, 2011 | Doro 530 Twin Cordless Phone
I faced error ##322 on my fax canon L250 how can i solve this problem. What is this mean how can i solve it.
Error 322 means that your fuser is not heating. For most cases it means that you have a bad fuser module, and needs to be replaces. Send your unit for servicing at any Canon-approved servicer.
Mar 03, 2011 | Canon FAX-L250
Canon Fax L250 says check printer error code #023. What to do?
This means that you have a memory transmission failure.
Can be caused by attempting to fax in the wrong mode. Use direct transmission method.
Nov 12, 2009 | Canon FAX-L250
I need to change the fax number on my Canon Fax L250
Press the funcktion button and then dataregistration.user settings will be display.Press the set button and scroll with the arrows until you find "unit tellephone " displayed press set and change number.
May 12, 2009 | Canon FAX-L250
Company heading
push the corner of the screen hard and it will work
Apr 22, 2009 | Canon FAX-L250
I have a canon fax L250 i can send a fax but i can not receive a fax please help
Call this number (12723 12) from your fax line to ensure the fax number you are calling is the correct number. The service will repeat the number of the line you are on back to you.
Does a normal handset ring when plugged onto the fax line and called?
Is the fax machine in manual or auto-receive mode?
Mar 02, 2009 | Canon FAX-L250
Fax L250 show ##322
there is a bad contact in the heater unit
Dec 04, 2008 | Canon FAX-L250
Add phone
Any analogue handset using an RJ-12 cable. (telephone extension cable). Their should be a socket on the back of the fax for this.
Jul 11, 2008 | Canon FAX-L250
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
