Question about Toshiba 53H71 53 in. Rear Projection Television
Toshiba 53H71 I moved three weeks ago. (Professional Movers). My Toshiba was working great until today. I had video and then the signal went out and the red power light started flashing on & off. Could not turn the unit off with remote of power switch. Unplugged and left it unplugged for about 15 min. Same problem when I plugged it back in. Could the move 350 mile have caused this?
  • Jody Daniel Aug 30, 2006
    One other thing was when we first hooked it up at the new home the color was off. I thought this might have been from the difference of switching from Direct Tv to Comcast cable. But it would change after it was set. Then "WHAM" no picture.
Your Television is going into protection shutdown. More than likely the problem will be sweep related IE Convergance is the most likely culprit your best bet is to have a technician look at it
Posted on Aug 16, 2007
House movers
need to look up a company and check their references and if they are able to get proper permits for your state and the other [s] at final destination
Jul 06, 2016 | Miscellaneous
My Toshiba 53H71 has no sound at all. Great
With a little background electronic knowledge and luck you may be able to do it. If all selections from the menu are correct and volume is not stuck in min its generally it due to broken wires or loose connections. The speakers are in front behind the front grill. remove it and checkout wires and connections. If all these are good and speakers are okay, the repairs would require professional help. down load the manual from tech support from this site and follow the flow chart for no audio fault. You will reach apoint where its solved or you have enough leads to decide in favor of professional help.
Mar 24, 2010 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53h71 Blue Shadow/Shade problem
If the shadow is off to one side then it's a convergence adjustment. If it is a blue outline it may be your blue focus. There should be focus knobs behind the speaker cover. They are usually covered by a piece of black tape. The convergence screen should have a prompt for changing the color you are controlling, possibly exit button. Toshiba has several of the older owner manuals on their site as archived models.
Aug 31, 2009 | Toshiba 53H71 53 in. Rear Projection...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Flashing Power Light
Toshiba rear projection with blinking LED =
1) Open micro fuse F850,851,etc....caused by
2) Bad solder connects....jumper wires 008,010,017,048,600
re-solder all and solder STK392-110 convergence amp pins.
3) Or consider replacing original IC's with improved version...
STK394-160 = Hitachi part # CZ 01341
.........................T.
Aug 30, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
