Question about HP Compaq nx8220 Notebook
I get the Blus screen when trying to install a fresh copy of XP on my nx8220
I need to re-install a fresh copy of XP Pro on my HP nx8220, the XP CD auto runs and goes through the file loading sequence at Windows Setup but then I get the Blue Screen of Death. I believe the next step on the fresh installation process is the formatting of ‘C’ and partitioning. The screen tells me to uninstall any recently installed soft/hard wear and any video adapters. It also suggests I check for any BIOS updates; I have done all this but am still getting the same problem. Apart from the Wireless drivers, internet explorer 7 and media player 11, there is nothing left on the machine. The Blue screen also tells me to disable Cashing or shadowing I’m a bit unsure of this.
Technical Information
STOP: 0x0000007E (0x0000005. 0xf78350bf, 0xf7c81208, 0xf7c80f08)
Pci,sys – Address – f78350bf bace at f782e000, Datestamp 367d855c.
  • wildwolf1 Oct 28, 2008
    thanks for your responce but I am running the XP cd from the boot.
    Scholar:
  • 136 Answers
If you are installing a fresh copy, you should boot from cd, and not start it from windows. It is less error prone.
Posted on Oct 28, 2008
  • velut_umbra Oct 28, 2008
    If you can get your hands on a Linux cd (Kubuntu 7 is excellent), use it to boot and select the MEM Test option. The problem might be in your RAM.
How do i load windows xp on hp nx8220 it goes to microsoft then back to start windows normally then repeats is there a solution thankx
the reason why is because ,hp computers use a different set of video drivers than does win/microsoft, when upgrading to xp you must install xp 1st release no svc pacs, then must have the hp video drivers oem for the model you are installing xp to , they can be downloaded on hp driver download, or the intel driver download site, unless you have a different chip set, the oem drivers must also be puton either a floppy disk or cd , that is made bootable from restart, make shure either the A drive or the C drive is set to boot before the hard drive so it will pick up the bootable disk you made with the downloaded drivers , then reboot the computer with the xp disk , at the disk partion screen select leave old files intact with the new install !
Jan 22, 2013 | HP Compaq nx8220 Notebook
Need Good & Free test and read/write surface scan tool for a Fujitsu MHT2040AH.
Try the ultimate boot CD, there you can use may hard drive diagnostic utilities, perhaps Test Disk will suit your needs, here;s a link
http://www.ultimatebootcd.com/download.html
Hope that helps
Christopher
May 17, 2012 | SimpleTech Simpledrive Computers &...
HP d220m will not boot from hard drive, have tried several but nothing happens.
Hello, can it be your cd or cd rom that is the problem? I sugggest that you try with a other cd rom and make a copy of your cd and try to install from the new one. Plz post your exact error here.
Apr 05, 2012 | HP Compaq d220M (829160054797) PC Desktop
Compaq NX8220 laptop reseting
Well it might be a factory default problem with the board, some times when systems are not fixed properly, it come up with such issue. I will advice you take it to service centre near you so as not to void the warranty.
Feb 29, 2012 | HP Compaq nx8220 Notebook
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
BLUE SCREEN ON HP WORKSTATION WHEN I TRY TO UPGRADE TO 64 BIT XP PRO
Are you trying to do a fresh install? or upgrade from another operating system? Generally have to do a fresh install when going from 32 bit version of xp to 64 bit. IF you have more than 4 GB of ram installed, you may have to remove some, then install 64 bit XP Pro, then install your ram after. (this is a known problem with some machines and 64 bit xp) IF this is none of the above?
Please add a comment with more information as per your BSOD. This way I can identify with you what it is the system does not like
Oct 08, 2009 | HP xw6400 Workstation PC Desktop
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
HP OFFICEJET PRO L7650 ALL-IN ONE TO DELL XP 2000 CANT GET TO INSTALL PROPERLY
hello jackjudy
are you trying to install with a cd ?
this could be a cd error, have you tried to download the software to pc form here select your o/s and download fresh drivers
Software & Driver downloads HP Officejet Pro L7650 Color All-in-One
riz.
Jul 07, 2008 | HP Computers & Internet
Dell Dimension 2350 restore cd or bootable cd.
go to pricegrabber.com to buy a new copy of XP. Save the stuff U want and install the new os. reload U'r saved data. If some of what U wnat to save are programs, U will have to reinstall those. The new XP os will self install from cd on boot up.
May 21, 2008 | Dell Dimension 2350 PC Desktop
HP Compaq nx8220 Notebook Logo
341 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
