SOURCE: Error code F3 on Kenmore 911.4658815 electric range
The oven temp. sensor has gone bad. Replace it and that will solve your problem. The part # is WB21X5301 and cost is $73.49. Can purchase at http://www3.sears.com/. You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&. It is inside the oven in the upper right or left hand corner. Should be able to remove from the inside. Two phillips screws and pull it out harness also. Plug new one into harness and put screws back in and you are done.
SOURCE: Whirlpool Gas Range E2 F3
Bake range over temperature, replacing the oven sensor is the easiest and most common solution for this problem.(w10181986) heres the part number
SOURCE: Whirlpool gas range model gw395leps00 error code e2 f3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
SOURCE: Error code E2 -F3- Everything works except the oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
