Question about Home
Jacuzzi J345 heat display blinking, heating light not on
3 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: jacuzzi tub not heating
O ring set may be required slow job take care
Posted on Oct 03, 2009
SOURCE: No heat with Rapid Heat U395000 Jacuzzi jetted tub
when you changed the heater did you make sure you also changed out the temp sensor cause most of the time calciun builds up an is the reason for both the heater an sensor to fail calcium is ok at temps above 93.6 degrees but as soon as the temp drops below this point it will come out of solution an start to harden on the element an sensor.Always make sure to that you are getting power from the spa pack to the heater check for voltage at the main leads on the heater just because it says its on does not always mean you are getting power to the heater.Always remember with spas the problem lies where the power dies.sometimes it can even be your main top side controls they can go bad an indicate the heat is on but will not relay that to the heater.make sure you got the correct kilowatt heater also an that you have the correct one in terms of 240v or 110v also from the thousands of heaters i have replaced in spas over the years i always check to see if i am getting the correct omhs reading before i install them should be around 8-10 for a 110 an 12-13 for a 240
Posted on Mar 27, 2010
How do I clear an air in a j345 jacuzzi
make sure all the unions to the pumps are tight
Sep 15, 2014 | Pool & Spa
Do you have a solution for the bearing of my rotating jet on a j345 spa ho broke once a year ?
i replaced the jet on my spa, check with you spa dealer for the correct part number.
May 06, 2014 | Jacuzzi Pool & Spa
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
My jacuzzi do not heat up the water anymore and the light on the panel is blinking on the heat light diode
check the pressure switch by bypassing it and see if the heat indicator stays lit.If it is not heating it could be a couple of things. First thing to check is the filter. remove it from the hot tub and see if that solves the problem.if it does not then perhaps the pressure switch is bad.always a chance you have a bad temp sensor if it is running but not heating if the heat indicator light is lighting up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Home
My jacuzzi is in lock out mode and cant remember how to get it out of that mode
normally this depends on top side layout but on most models you press HEAT button then LIGHT or HEAT then BLOWER.
Nov 24, 2010 | Jacuzzi Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Jacuzzi tub not heating
Sep 18, 2009 | Home
Continuous low speed, no heat
At this point after having spent all that money, you have to figure something else is frying those boards.
You need to make a decision whether to A: Call a Jacuzzi repair specialist
B: Replace the the control panel, the board, and possibly even the heater and pump, thermometer and sensors.
C: Cut your losses and buy a new Jacuzzi. Trade this one in on it for whatever you can get. And from personal experience, stay the h*** away from Ebay when it comes to electronics.
May 21, 2009 | Home
MY JACUZZI HOT TUB STOPPED HEATING
sounds like it could be either the heating element, the thermostat or pressure switch problem. Does the light come on when it is trying to heat? if it doesn't come on then most likely the heating element needs to be changed.
Dec 13, 2008 | Home
Home Logo
167 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
