Question about HP ScanJet 5470 Flatbed Scanner
Power connector pinout - HP ScanJet 5470 Flatbed Scanner
  • kistler Feb 22, 2012
    I'm confused because the power adapter that I have been using for several years is rated at 12 volts while the information that I find on the web for HP 4570C scanner indicates that it requires 24 volts. My earlier question on the pinout of the adapter was answered by carefully observing the markings on the adapter (VERY SMALL) so I believe the 12 volt is correct since only two of the four pins on the connector are shown to be active. Were some earlier versions of the HP 4570C scanner configured to run on only 12 volts? I'm about to open the unit and see what there is to see but would appreciate any comments others may have. THANKS, Jim
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Need power connector pinout for FSI PRISM camera
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Aug 24, 2012 | Cars & Trucks
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
I m trying to install a new motherboard and i need the manual or motherboard diagram for the pinout for the power connector
You need to specify the motherboard's make & model in order that I could provide you with further assistance.
Mar 24, 2010 | Computers & Internet
Power supply pinout for IBM PC
check these 2 atx power supply connector image.
click here
click here
Aug 13, 2009 | Computers & Internet
Need the schematic to plug in the power connectors
This link http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
is a great page for the standard ATX pinout and related info.
WARNNING dell's and some other psu's have a different layout.
If you look onto the power supply box, you will see a modle like
ATX130p3, google this with "pinout".
Aug 07, 2009 | HP Compaq Evo w4000 PC Desktop
I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
http://eu.shuttle.com/download/Archive/Manuals/en/mv43p_n/mv43pen.zip
Good luck,
Don't forget to rate my solution, thanks!!!
Jan 15, 2009 | Shuttle MV43VN Motherboard
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
HP ScanJet 5470 Flatbed Scanner Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
