Question about Panasonic SC-BT100 Theater System
I have my sky HD Box connected to the system via an optical input. The cable is glowing red so is working. I have the sytem set to D - IN yet there is no sound. This happened following a period where the sound was cutting in and out at regular intervals. No settings have been changed. Incidently when I run the optical cable directly from the TV, again there is no sound. Radio works fine, DVD'S no roblem. It is just the Digital Input
  • Jonathan Kellett Feb 21, 2012
    T.V is connected to theatre system and sky box via HDMI
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: can't get HTS to play
below is feature of your sony HD KDL-32ex523.
Headphone/Analog Output: The TV's side-panel 3.5mm analog output can be used to connect a set of headphones or as an audio output to connect your home theater receiver or soundbar system. You can set the TV's analog output to Fixed or Variable. You can set the TV to automatically mute the built-in speakers when a set of headphones are connected.
Regarding the above, I would recommend you use a 3.5mm to RCA cord to get audio from the TV through your HTC. Below is a picture of what the 3.5mm to RCA cord looks like:
Now purchase this cord if you don't have one.
Connect the 3.5mm part to the headphone jack of your TV and the other RCA part to Aux of your HTC. By so doing, there should be sound from your TV coming through the HTC.
I hope the above is clear. If not, please let me know.
Regards.
Posted on Sep 15, 2011
I just bought a samsung home theater in a box system, model Ht-D5500. And i also have a hd cable box. i was wondering how can i connect my cable box up so that i get audio from the speakers instead of the...
There are two ways of connecting to get cable TV audio from your Home Theater System.
1) If your HD cable box has a digital audio out ( either optical or coaxial ) you can connect this to the Samsung Home Theater Systems digital input. While watching a TV channel scroll through the Samsungs input ( source ) selector till you hear the sound. Remember to mute the TV sound while you are doing this.Most probably it will be the CBL/SAT input or Video AUX.
2) If your HD box does not have digital audio out you can connect the Red & White audio out of the same to your Samsungs Aux or TV or Video audio inputs . Ignore the yellow socket and connect only the Red and White audio inputs.For getting Video through the TV connect the HD box to TV via HDMI cable or connect the Yellow video out to the TV's Yellow video in. I am sure it is already connected .
Mar 21, 2011 | Audio Players & Recorders
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
http://hd.sky.com/hd-television-equipment/hd-set-top-box/
http://hd.sky.com/hd-television-equipment/input-output-connections/
http://www.ehow.com/how_5890852_convert-hdmi-rca.html
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Mar 11, 2011 | Sony DAV-S300 System
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Problem with optical input of lght 33s surround
If the slot in the LG system is an input then it won't necessarily show a red light. The connectors are usually very positive though, so check that the TOSlink connector is the right way around, and that there is nothing in the socket which is stopping it from engaging.
Jul 20, 2010 | LG Audio Players & Recorders
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Popping noise through speaker when changing channel on sky hd
What make is your HD Box and TV? Assume you are connecting direct to your TV using HDMI, and not though an amp? If you do have an amp, you'll need an optical from HD box to amp to get DD 5.1, and connect your HD box to TV with the HDMI. Have you disconnected any scart connections from the HD box to TV - no longer required unless you really want to watch SD over the scart? Check that the Audio Output in the Sound settings for you HD box is set to Stereo.
Does your TV have individual audio and picture settings for the input source - perhaps you need to tweak these for the HDMI input being used. Do you have another HDMI cable you can use to eliminate a possible dud?
Mar 18, 2010 | Sony HT-DDWG700 Theater System
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Digital Sound from Sky HD and DVD player to Lifestyle 8 series 2.
I HAD BREAK DVD NOT OPEN AND I STILL LOOK FOR NAME JVC-DVD DIGITAL THEATER SYSYEM TH-C7
Apr 07, 2009 | Bose Lifestyle 8 series II System
TV and Sky hd to samsung HT-Z310
connect 1. cable/satellite box to TV with HDMI. 2. cable/sat box to sound system using optical cable. 3.change box sound setting to optical/dolby.
Jan 22, 2009 | Samsung HT-Z310T Theater System
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Panasonic SC-BT100 Theater System Logo
126 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
