Question about Garden
536.797520 govenor linkage
When trying to generate electricity, it stalls. Oil level good and carb has been cleaned thoroughly. Linkage for auto throttle up is moving like designed. Any thoughts?
will assume it a petrol not a diesel
that govenor is adjustable
with all the load and vibration and use
sometimes that govenor adjustment will need a twig
lever moving up and down is a good sign
does it need a spark plug
or valve adjustment
if all that is ok
if you push that lever slowly full forward and motor stalls
may tell you its govenor needs a twig
Oct 08, 2016 | Electrical Supplies
I have a toro gts 6.5hp model 20017. The enginer is overreving a lot. I had changed the carburetor and believe i put the linkages correctly, however i noticed the governor arm is rotated slightly right...
The way i set the govenor is, slacken the screw on the engine govenor arm, push the arm fully over to open the throttle wide open, now turn the actual govenor shaft within the arm in the same direction, fully retighten the govenor arm screw,
Sep 29, 2013 | Toro Super Recycler Super Bagger Lawn...
Runs wide open when started and stays that way
It is the governor linkage not connected up properly
Jul 21, 2013 | Measuring Tools & Sensors
I am removing a Kohler engine from a simplicity lawn tractor. I was told that the govenor gear inside the engine is not working because the engine just started racing (RPM's) I check teh linkage and...
While there may be a governor, I doubt that is the problem.
It is more likely just the linkage to the carburetor.
And you don't have to take the engine out to get to the carb.
Take the air cleaner off, and examine the carb butterfly.
There is a choke fast idle cam that is probably not in the correct position.
Aug 19, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
The auto throttle doesn't kick on, runs full boar constantly
This is likely a govenor problem. Some of these problems are caused by a lost spring on the govenor linkage.
Apr 22, 2010 | Honda Electrical Supplies
My troy built bronco revs excessively, and will not power down with the hand control.
sounds like the govenor linkage is bent or has come off.replace the govenor linkage with a replacement..good luck
Apr 15, 2010 | Garden
I had to repair pull cord, in doing so I took the throttle linkage carborator linkages off to get to the pull rope housing. I need schematics to show all the throttle control springs wire hook up to get...
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Feb 03, 2010 | Craftsman Rear Mount Tiller
Need exploded view of carb n governor linkage n spring location
the govenor spring fits in with the throttle linkage and the other end goes in the govenor...good luck
Nov 07, 2009 | Garden
Carb and throttle linkage on a Tecumsen LEV120 361015A
You want the spring to hold tension against the governor.
May 17, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
