Printer light is blinking
My printer will not work well print , i have a hpofficejet pro k5400 , there is a light blinking on it and this is the first time i sen it , i tried everything to fix it but i need help
  • 3 Answers
When something like that happens with ours, we can usually just power it off and then back on to fix the problem. If that doesn't work, try unplugging it for a couple of minutes and then plugging it back in.
Posted on Dec 13, 2008
Is the green light on my Office jet k5400 suppose to be blinking?
the green light on your printer can be blinking, here are the causes:
  • The printer is either turning on or off.
  • The printer is processing a print job.
  • The printer is paused while the ink dries.
Just try to wait for a while, and it should be all right again.
Lucas
Jul 11, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Hp k5400 light blinking, can't print
The blinking means the cartridge is out of ink and needs replacing.
Jun 24, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
Hi - I have a HP Officejet Pro K5400 printer. That printer & my Dell Optiplex GX620 was left on during a 2 week office absence. When I returned the blue ink cartridge indicator light was blinking and...
Please follow the steps in the order below and check.
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
Now perform these steps on the computer...
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
now please print and check
May 20, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Help with my k5400
It's possible you have one of the following problems:
  • Printhead is faulty
  • The printhead has expired (HP printheads have an expiry date which is written into the chip)
    In both of these cases contact HP support to request a warranty replacement (but try the ideas below first obviously :))
  • The printhead hasn't been inserted properly
  • The chip contacts are dirty or soiled in some way
    For these last two, try removing the printhead, cleaning the chip carefully with a cotton bud and then replacing carefully.
It's also entirely possible that you've been sold a lemon in which case you need to call the store you bought the printer from and get them to troubleshoot the issue with you and/or replace it/refund your money.
Hope that helps.
Jun 11, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Officejet K5400 Won't print black
  • If there are defects on the page, run a Level 3 clean from the control panel of the printer. Follow the steps below:
    1. Press and hold the Power button.
    2. Press the Cancel button one time and the Resume button nine times.
    3. Release the Power button.
May 15, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 - print pausing
print as image tick it than it will work
Jan 19, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
67 people viewed this question
k24674
jasbo
jasbo
