Question about Gateway Computers & Internet
Schematic for dx4300 motherboard - Gateway Computers & Internet
Tip
Schematics + diagrams + laptop + desktop + motherboards
on Mar 11, 2015 | Computers & Internet
Need a wiring diagram for a Gateway DX4300-03 system board
Need to know board model and those cases are wired so the plugs fit the original board. Your best bet would be to just get a new tower case. www.tigerdirect.com has them for $25
Dec 11, 2013 | Computers & Internet
Gateway dx4300
One of two possibilities; the Motherboard or power supply. In my case it was the Motherboard. Those cheap capacitors tend to go bad over time without being used. I purchased a replacement motherboard(Foxconn RS 780 "bengal") from a place in WI. Skyline on Ebay. I would do a search on Ebay for Gateway Foxconn Bengal RS780 Motherboard. Then get the number and call. You can use the old processor, ram, and maybe the graphics card, but I'd run the onboard graphics first(if you do happen to have replaced the motherboard) to make sure the graphics card isn't causing an issue. You will need to do some research and reading on the net about installing new motherboards and hardware. If the motherboard is the same, Windows should still work with it. Do your homework first as this is only a suggestion as to your problem. It is what happened to my Gateway DX4300-03. Check all power supply related, graphics card and wire connections first before you consider the motherboard thing.
Oct 12, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
Motherboard troubleshoot
Try removing the graphics card and any un-necessary PCI components, and plug monitor in using the provided onboard VGA slot.
Jun 08, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
I need to connect the switch leads for power,reset, and HDD LED activity to my front panel LED to the corresponding connectors on the motherboard for the Gateway DX4300-03.
PinSignal NameIn/OutDescriptionPinSignal NameIn/OutDescription1HD_PWROutHard disk LED pullup (5 V, 15 mA max)2HD_BLNK_GRN+BLNKOutFront panel green LED3HD Active#OutHard disk active LED4HD_BLNK_YLW_BLNKOutFront panel yellow LED5GND Ground6SW_ON#InFront panel On/Off button7FP_RESET#InFront panel Reset button8GND Ground9+5 VOut 10FPSLP#InFront panel Sleep button11IRRXInIrDA serial input12GND Ground13GND Ground14Key Not connected15IRTXOutIrDA serial output16+5 VOutIR power
Nov 29, 2011 | Gateway DX4300-03 Desktop PC
Gateway dx4300-11 won't power on after put in
Is the Gateway DX4300 having problems while installing the drivers after sleep mode
or does it have these problems during the laptop is turned on.
Always make sure you download the right drivers for your system.
If you installed Windows Vista after you had formatted the system and now your trying
to install them you might want to go on another system and download all of the drivers either on an external hard drive or an SD card so everything can be accessible.
After you install Windows Vista or 7 make sure that the compatibility mode is selected while installing the drivers.
Most of Gateway drivers are Windows XP so you have to go and right click on each and every driver and change the compatibility mode to Windows XP SP2 that way when you let it install then Windows Update will activate to perform updates for hardware drivers and software applications. It will also get the KB updates for your computer.
This will probably fix the sleep mode and improve it too.
1. Go on Gateway's site
2. Download the DX4300-11 drivers and make sure its directly from
Gateway on a SD card or external hard drive.
3. Change the compatibility mode to Windows XP SP2
and let it run as administrator.
Each driver will then install and then you will fully use
your computer's capability.
After the drivers are installed then change your power options
as it will continue to install your drivers.
Check to make sure that your battery is fully charged and is plugged in
if it is. If not plug in for charging the battery.
If all fails then you will need to replace the motherboard.
Sep 26, 2011 | Gateway Computers & Internet
Hi - recently I've been getting a no signal message on my monitor - system is still runnung but no video. I have checked cables - all are OK - The computer is a Gateway DX4300
Three major components usually is causing this kind of problem. One is the memory card. Two the video card . and lastly worst is the motherboard. Check and clean your memory card first then put it back to its place of slot. Start your computer. If you hear one beep but still no pictures, the problem lies in your video card. If there's still no beep sound and picture, and you think your memory card is good, try to clean your video card, then start your computer. If there is still no picture, and you think your video card is good, then you have a problem with your motherboard. Indication that your cpu is working were, beeping sounds, lead lights blinking or changing sequence is present. If it is present, your monitor has a defect an needs to be replaced.But if none of this is present, we have a motherboard problem.
Sep 04, 2011 | Gateway DX4300-03 Desktop PC
Computers & Internet Logo
82 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
