Question about Malber WD1000 Front Load Washer/Dryer
Part list for malber wd 800
Door latch and detergent dispser
  • 13 Answers
SOURCE: MALBER WD 1000- CAN I USE LIQUID BLEACH?
Liquid detergent and liquid bleach are best.
Posted on Jan 07, 2008
  • 1294 Answers
SOURCE: MALBER WD 800
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 04, 2008
CMV9
  • 594 Answers
SOURCE: Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Posted on Aug 14, 2008
  • 417 Answers
SOURCE: What kind of detergent do I use on my Malber WD 1000?
Choice of detergent should be straightforward subject to personal preference;
Concentrated is usually more economical, as you don't have to use as much as with UNconcentrated.
Liquid or powder is no contest, it's liquid every time, it dissolves better in harder water areas and doesn't clog up your dispenser.
Brand choice depends on where you live, we use Persil but supermarket own brands are usually a lot cheaper eg Carrefour.
Hope this is useful
Please remember to give this solution a rating.
Posted on Oct 22, 2008
SOURCE: MALBER WD 800 Features
I have a manual if you wold like a copy.. I can fax it to you
Heartcracker6@yahoo.com
Posted on May 18, 2009
Malber WD2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won't release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don't pull too ******* the white door handle. If you can't open it with your little finger (seriously) it's not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Broke the door handle on malber wd 1000? Do they sell the handle or door?
Sorry to see this 16 months too late.
You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 30, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber combo doesn't start
This problem is usually the front door latch "interlock" is not engaging. This is the safety device which keeps you from opening the door and pouring gallons of water on your feet. When you close the door, if the machine DOESN'T recognize it's closed - all electricity is cut off and the machine does nothing. If the machine DOES recognize the door is latched, the latch will lock and you can't open the door (for about 90 secs after you turn it off or unplug it). Does the door LOCK when it's closed? If not, just close it harder several times. A medium "slam" almost always takes care of a "sticky" interlock - and it doesn't hurt anything.
Aug 01, 2012 | Malber WD1000 Front Load Washer/Dryer
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
Mar 31, 2009 | Malber WD1000 Front Load Washer/Dryer
Hope this is useful
Oct 22, 2008 | Malber WD1000 Front Load Washer/Dryer
MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
May 02, 2008 | Washing Machines
MALBER WD 800
Feb 03, 2008 | Malber WD1000 Front Load Washer/Dryer
Aug 21, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
209 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
