Question about Dell 1700 Laser Printer
Black marks on the side
How will get rid of black marks on the side of the paper? I tried to clean drum with air spray and I'm still getting it.
  • Anonymous Dec 01, 2008
    I have been having the same problem. There are black smudges along the side of the paper. pLease help!
It means you need to change out your drum.
Posted on May 28, 2009
How do I clean my drafting table cover?
You can use any cleaner to get rid of the marks on the cover. I use whatever spray bottle of cleaning fluid I have around the house. Make sure to clean regularly or your papers will get smudged from the pen marks
Jan 03, 2013 | Furniture
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
There is a black line down one side of the paper. how do you get rid of that?
Your problem may be either a bad drum or fuser unit. Look at the drum and check for any scratches or toner there. Check the fuser unit for a black ring on it that may deposit toner onyour paper. Be careful as the fuser unit is quite hot! Also make sure the inside of the printer is clean. Y ou may vacuum it out. Caution! Don't blow it out with canned air. You'll just spread any toner all inside the printer.
Feb 18, 2011 | Brother HL-2170W Laser Printer
I have a smudge on the right side of paper when printing on my lexmark E250dn printer. How can Iget rid of this smudge?
You have a mark on the drum. Find the drum cartridge and rotate the drum by the gear until you find a mark on the surface of the drum. You can try wipe it off with a very soft dry cloth but it is unlikely that this will be a cure and you will probably have replace the drum cartridge (+ $70). Do not try to clean it with any solvents or polishing material.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
Black mark printing on side of paper
it is step by step process
1. Clean the printer with air pressure before that all removable items like toner, drum kit , paper tray etc.. completely clean. try to make printer if problem still persist
2.second thing change the toner
3. Back side of the printer, check the fuser kit any black mark or any damage
please try..
In Case You Still Having Problem Then Follow Us For On:
Brother Printer Support
Nov 16, 2010 | Brother HL4040CDN Duplex Unit
Canon 4050 copier has line down the paper. How do I get rid of it
take out toner and shake it to clean the toner cartridge
or you need a new drum
Apr 16, 2009 | Canon NP 6050 Copier
Printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Sep 16, 2008 | HP DeskJet 6540 InkJet Printer
Printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Dec 31, 2007 | Kyocera Mita FS-1920 Laser Printer
Dell 1700 Laser Printer Logo
133 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
