I need to know where the power antenna motor is.
I have not owned a buick for years. However, the one I did have trouble with the power antenna motor was located directly under the antenna. It was in the rear fender housing. I have to remove the trunk lining on the side of the fender. It was mounted a bracket. It was easy to replace as it all comes as a complete assembly. Hope that helped
Inside the trim panel at yhe bottom of the antenna mast.
SOURCE: secondary air pump 2000 buick regal
The pump is located at the left front inner fender forward of the left front wheel. You may remove the inner linning for better access. Please inquire for the TSB update on the pump at the dealer.
SOURCE: power steering fluid leaking;
Fill it up. Have a helper hold the steering wheel to all the way to the stop while you check for leaks. Especially the high pressure hose.
SOURCE: 92 buick century power antenna motor wont shut off
Well, even if you pull the connector (under carpet) apart with gray white and green wires(ones seen going to motor from door gap when opened) it still doesn't stop. next access point is from behind mud gaurd in wheel well. If I can't disconnect it from there I will just cut the bloody wires.
