Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore Upright Freezer Works Sometime
I have an older upright Kenmore freezer, 13 cubic feet. It's a manual defrost, no light, no bells or whistles. One day last week it shut off and started to defrost. I unplugged it for a few hours and when I pluuged it back in it started working fine. It worked fine all weekend then last night it shut off and won't start. It clicks like its trying to start then a few seconds later it clicks like it turning off. A couple of minutes later it trys to go through the cycle again. Then after a few minutes, it'll click and the compressor will come on work fine, freezes a cup of water. Then, when it switches off it won't start until it clicks on and off a few times. What part should I replace...first?? Or, do I buy a new one??
  • 124 Answers
Try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Posted on Nov 06, 2008
Can you tell me how large (in cubic feet) this freezer is?
Is this a trick question? It is 20.3 cubic feet according to your question. This may be the capacity or the size of gross measurement ... you have not indicated.
Please ask the actual question you want to know ...
Thank you
Mar 22, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How do you defrost a older modle 13 cu ft standup freezer ?
Empty it out....pull the plug... get out the hair dryer....when all of the ice is thawed and the water soaked up then you plug it back in and restock the food...
Jan 30, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Is a Kenmore upright freezer model 253.23424102 frost free?
No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 26, 2010 | Kenmore Freezers
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore manual upright freezer
we got alot of ice chest and cleaned out the ice. this fixed the problem so far. we dint lose any food thank goodness.
Jul 07, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Jun 25, 2008 | Freezers
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
202 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
