Question about Acer Veriton Computers & Internet
Wrong graphics card set as default on my acer veriton m2 series it now wont run a monitor and dont know how to get original setting back with no access to bios
  • 409 Answers
Clear CMOS to return to defaults...
Posted on Feb 21, 2012
Benimur
  • 6966 Answers
SOURCE: AGP 4X
Specs sheets for an Acer Veriton 5200 says that it has one AGP 2X/4X expansion slot, therefore the answer to your query would be a yes. Even if your add-on video card is 8X, it would still work however the card would downgrade itself to only $4X.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
frcs68
  • 1605 Answers
SOURCE: Acer Veriton M464 - BIOS options disabled by default
no. BIOS is manually enable and disable hardware function in the machine. it prevent detection of uninstalled hardware.
if you enable all of the options, the machine will not be able to power up because some of the hardwares are not installed.
Posted on Apr 07, 2009
theSuit
  • 35 Answers
SOURCE: my acer veriton m661 desktop--i cannot set the
If your computer boots up fine, it should be be the bios battery. Flashing with the wrong bios usually makes your computer completely unusable (showing only a black screen), so I think this is not the case.
You will need a CR 2032 lithium 'button'-battery. If you havent got one lying around, try a local radioshack, photo supplies shop or watch shop.
Replacing the battery is pretty simple: remove all the computer cables, open up your computer (touch a metal part of the casing first to rid yourself of any static), locate and replace the battery on the motherboard. Put it all back together and voilà.
(the first time you boot up again, your pc will give another checksum error, but you should be able to set the time. On the next bootup, there should be no 'checksum error' message, and the time should be correct)
You can find some extra info on here: http://www.hardwaresecrets.com/article/81
Posted on Dec 13, 2009
potek18
  • 528 Answers
SOURCE: acer veriton 5800 desktop .- sata hard disk not detected
update bios if this didnt work, reseat hard drive
Posted on Mar 29, 2010
Jaketech
  • 67 Answers
SOURCE: acer veriton m2 series network drivers
Just go to this link:
http://gd.panam.acer.com/home/
and select Desktop, Veriton, and then your specific model, and you will get a list of the drivers for that model that you can download and save or run.
Posted on Jul 22, 2010
How do i set up a acer veriton l480g desktop computer
Pretty straight forward
- Video monitor plug goes in plug on back of PC that matches
- Sound system - plug green plug into matching green port on PC
- Power cord in matching port on back of PC
- Internet cable goes in port that looks like cable plug
- USB plugs go in matching ports on back of PB
- they can only be installed one way
- It doesn't matter which port they are plugged into
Sep 04, 2014 | Acer Veriton L480G-UD7600C - Core Duo...
Fitting an external PCI graphics card ... issues.
Go into the device manager find the card you do not want to use then disable it do not delete it. Restart the computer making sure that your display is plugged in you want to use and it should show up. The way your doing it is allowing both monitors to or both drivers are active. John
Apr 16, 2012 | Acer Veriton M420 PC Desktop
Acer veriton m2 series network drivers
Jul 07, 2010 | Acer Computers & Internet
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Can not start acer veriton 5600g with ati 1650 pro agp card ? The bios doesn't seem to recognise the card and it beeps when i disconnect the onboard vga. Any help will be appreciated... thanks
How did you disconnect the onboard VGA?
The onboard VGA device must be disabled in the BIOS and the ATI graphics card inserted in the computer.
When you bootup it should default to a standard Windows VGA configuration, then install the ATI video driver o you can get high resolution graphics.
Jun 24, 2009 | Acer Veriton 5600G PC Desktop
Neon blue hurts my eyes
You might wanna reset your monitor's settings to default, just play with your monitor's options untill you find the reset to default option. If resetting the monitor's settings doesnt work, then try resetting your video card's settings. right click the desktop and open your video card's control panel, then look for the reset to default options, especially on the color settings, wherever they are (control panels for graphic cards vary by vendor ie ATI/Nvidia, and/or by the control panel's version)
Jun 11, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
No image
try control panel, dispaly settings, monitor, change default monitor.
Let me know if this works for you.
Jan 15, 2008 | ASUS A9250/TD Radeon 9250, (128 MB)...
Computers & Internet Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
