Question about LG LSC27931S Side by Side Refrigerator
Lg lsc 27921 - LG LSC27931S Side by Side Refrigerator
  • 1 more comment
  • shashaska199
    shashaska199 Feb 21, 2012
    how to fix the icemaker, it only fills half the tray
  • Ryan Trazo Feb 21, 2012
    What is your problem with your Refrigerator?
  • shashaska199
    The ice maker stopped filling the whole ice cube tray instead it only fills 4 out of the 8 cubes and I'm not sure how to fix it
LG side by side Model LSC 26905
Insulation does not melt - gaskets may be affected by hot temps.
Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
Jul 29, 2016 | LG LSC26905TT Side by Side Refrigerator
Lg ice maker overflow
The ice tray warps after so many years and is no longer level. Replace ice tray for $3.05 from RepairClinic.com Item #1266779 ...From what I can see this Item is the same for for all LSC #######TT refrig.icemakers. Another solution I found was to adjust the flow amount into the tray. The only screw that might have worked for this did not turn.
May 11, 2012 | LG LSC26905TT Side by Side Refrigerator
Lg lsc 26945sw freezer not getting cold
clean off coils on back or under bottom of freezer
Feb 29, 2012 | LG LSC26905TT Side by Side Refrigerator
My LG LSC 26905TT Refrigerator started to heat up around the outside of the freezer side/top and center bar between the fridge and freezer. The freezer is not freezing no matter how high we set it or the...
HI.IF THE REFRIGERATO BOX OR DIVIDER IS HOT ,CHECK THE CONDENSER MOTOR ,FOR RESISTANCE OR CONTINUITY,CHECK FOR POWER COMMING TO CONDENC MOTOR,, IS OK REPLACE THE CONTROL BOARD OR REPLACE BOTH..GOOD LUCK..
Jul 04, 2011 | LG LSC26905TT Side by Side Refrigerator
LG LSC 26905SW control panel for temp, ice,
Replace the control pnl.
There is no way to fix the existing control.
Jan 12, 2010 | LG Refrigerators
Display stops working
new control.
and LG parts are only available through LG at this time
Oct 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Where is the water filter located on my LG LSC 26905TT refrigerator?
Open the left door, look up to left top, there should be and s looking cap.
Jul 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Side by side refrigerator - LSC 27950SW - looking
most likely water is running out the corner of your ice maker and into auger bucket and freezing not allowing it to dispense.check bucket to see if sheet of ice is forming.
Mar 06, 2009 | LG LSC27950 Side by Side Refrigerator
LG LSC27931S Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
