Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
HOMELITE 330 can you tell me the tuining ratio for the carb
  • Actuator Dec 21, 2008
    With air filter off, there seem to be much fuel exiting the carb. id this normal. unit runs strong then stopd
The Homelite 330 has a set of "reed valves" (thin fiberglass flaps held in a V shaped holder, narro end of the V point to the engine) in between the carburetor and the intake port of the cylinder.
Looke here http://books.google.com/books?id=ISzSHyegUSYC&pg=PA218&lpg=PA217&ots=TiCmMmPbXi&dq=330+operators+manual+homelite#PPA218,M1
then look at part #26 on page 218.
basically it does:
Airflow Reed Valve engine
Their function is to open slightly when the air is rushing through them toward the engine, and yet flap closed again to stop the backflow or air/fuel from going out of the cylinder. The sucking action of the engine lets the air slightly move the reed off of the small part of the "V" and the air flows in. As the airflow is reduced the mechanical tension of the reed, trying to remain flat and not bent, closes it.
Since they are flaps there is a momentary time then the air will rush out as they close. But you not should see "lots" of fuel coming out of the carburetor.
Two symptoms will cause excess fuel/air rushing out of the carb.
1. if they are old the reeds can be slightly warped and just not seal against the reed valve cage. That means replacing the reeds (if servicable) or the reed valve (cage and reeds together).
2. If any dirt or sawdust ever got into the engine, there could be some particles stuck between the reed valve and the cage. This is usually near the top of the reed valve and once it's in there, it can't get out. You can sometimes tage out the reed valve cage, remove the reeds and clean everything. The foam seal around the perimeter if the black top cover of the Homelite 330 usually breaks down over time and lets dirt/fine sawdust into the "Clean side" of the air system. You should see no dirt/sawdust or debrea around the carburetor.
In either event you would want to make sure that when you are lookin at the part that the reeds are perfectly seated on the reed valve cage. If not, you get the symptoms that you described.
Stuart
Posted on Jan 28, 2009
  • 211 Answers
Hi phil846
try high speed h=2turn and low speed L=2 and a half tu
adjust the T
best wishes savumihai71
Posted on Dec 02, 2008
Tried replacing welch plug and broke
take the carb to a carb centre
Mar 23, 2014 | Homelite Garden
Fuel line routing
i took the homelite 330apart in doing so the lines broke no problem i needed to replace them any way so now im confused to where they all go
Oct 01, 2013 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Nov 13, 2008 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
1,381 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
