Question about Emerson LC320EM9 32 in. LCD HDTV
Foggy picture try contrast and bright, didn't work. and is 30 on the picture settings the norm.
    Top Expert:
  • Emerson Master
  • 78,919 Answers
You have a failed part in the TV's electronics, this is not something you can adjust out.
Posted on Feb 21, 2012
What are the best picture calibration settings for the sony 4k xbr65x850a tv
Brightness to 40 > 50%, Contrast to 65 > 75% & Color to 30 > 35% must give a good picture. First, try to adjust a good B/W picture, by adjusting the brightness and contrast. After you have got a good picture in B/W, then advance the color intensity, according your viewing taste. Gopakumar Gopalan Google
May 30, 2014 | Televison & Video
The picture is so dark can't make out figures
It sounds that the back-light section has some fault with your TV. Otherwise, 30% brightness, 60 to 65% contrast, and 20 to 30% color settings should give you perfect picture.
Jun 06, 2013 | Digimate DGL20 Television
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Want to know how to adjust contrast
Very old set--always adjust so contrast not too high--it should always be lower than brightness---say brightness at 75% and contrast lower--if contrast set too high smearing will occur and picture quality will be affected.
Apr 08, 2012 | Televison & Video
I have installed recently WIN XP SP3 on my samsung netbook N100. I observed the LCD gives sufficient brightness and Contrast when charger is on while with battery backup brightness & contrast...
I believe there's a setting in your control panel > power options to change the settings of the brightness and contrast depending on the source of power. it is set there to change the brightness and contrast of the LCD on how it will change once you remove the ac adapter from the laptop.
Hope this helps!
Sep 21, 2011 | Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have a tube tv. the picture as lines and is blur that goes in and out.
If the lines are colored DIAGONAL lines, they are referred to as "retrace lines," which indicates either that the picture tube bias is set too high, or the brightness level is set too high.. If the blur occurs when the image is particularly bright or a particular color is bright, it is referred to as "blooming." This is caused by either a weak high voltage circuit or because the picture tube bias is set too high.
Is the picture set very bright? Try reducing the brightness control to a level where the retrace lines disappear, and reducing the contrast control below the level where the blooming occurs.
If the television is more than ten years old or has many hours of use, the picture tube may simply be deteriorating normally. By nature, they have a limited life span. Before you decide to throw the set out, if you are technically-inclined, try adjusting the bias and screen drive controls for the television as recommended by the set manufacturer (you didn't specify what make or model the set is), and you may get a few months or years of additional life out of the set.
Jul 05, 2011 | Televison & Video
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
JUST BOUGHT LG42LF66 FULL HD 1080P WOULD LIKE 2 KNOW BEST XD ENGINE SETTINGS AND COLOR,BRIGHTNESS,CONTRASR AND SHARPNESS SETTINGS THANKS J.SINGH
set my one like this:
picture mode=User1, contrast=60, Brightness=60, colour=30, sharpness=100, tint=standard setting.
colour temp.=cool, XD: contrast=off, colour=off, xdnr=high, mpeg nr=15.
Used gold plated scart for dvd & sky, picture looks pretty good, have not tried hd yet. Initial settings when first switched on were **** but with some tweaking have got good results.You probably have it set up pretty good now but just got mine & thought I would post this anyway.
Apr 23, 2008 | LG Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Emerson LC320EM9 32 in. LCD HDTV Logo
59 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
