Question about Sport & Outdoor - Others
Ski-doo running on one cylinder,has compression,has light spark,but themachine will run,what could the problem be?thanks
warlock61
  • 659 Answers
SOURCE: Car is running rough, afetr spark plug change
make sure no fuel is down in the spark plug ports it will short out the spark
Posted on Apr 15, 2009
  • 65 Answers
SOURCE: 1982 kawasaki 550 stand up ski-doo,starving for fuel
fuel pump ? checked pop off presure in carbs?
Posted on May 07, 2009
  • 1596 Answers
SOURCE: 1997 Nissan Altima Cylinder 1 misfire detected.
This Sounds Like a COIL PACK Problem
Posted on Aug 05, 2009
  • 321 Answers
SOURCE: 1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Posted on Aug 29, 2009
  • 9 Answers
SOURCE: i own a 380 gtx ski-doo,which just started blowing
its not water tight - make sure all seals and gasjkets are in place
Posted on Dec 20, 2009
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
08 ski-doo gtx 500ss lost power to one cylinder, lots of spark, plug dirty. Blown piston? Cause?
check it's getting fuel to that cylinder, if so would suspect piston ring or leaking valve. burning blue smoke from exhaust is a clue.
Mar 02, 2015 | Cars & Trucks
My 2009 tnt exec skidoo loses power after I run it for 10 or 15 minutes
Do a compression ck. the warmer the engine the less compression.
Feb 26, 2015 | Ski-Doo 2009 MX Z TNT 600 H.O. E-TEC
200 2002 ski doo 700 fill left crank case with 2 stroke oil so bad that when we started it bent A rod P
Oil does not go directly into the Crank, I am afraid you have (Dirty Carb) or Low Compression. What it sounds like is you HYDRO LOCKED your CYLINDER (not completely) and when you started it, it can not compress a liquid and BAM,,..,, Time for a new engine
Feb 05, 2015 | Winter Sports
I have a 2001 ski doo formula 380. It has little or no power.
Is it running on both cylinders or just one, if it's out on one cylinder, clean the carbs and replace the plugs and wires, wires are already bad on my 2009 gtx 550, so I just taped them with electrical tape as a temporary measure.
Jan 31, 2015 | Winter Sports
Ski doo engine troubleshooting
What is your Issue?
What are you troubleshooting?
What is it doing?
Misfire?
Lack of Power?
Engine Light?
Have you Checked your Compression?
Do you have a Dirty Carburator?
We need much more information..
Jan 02, 2014 | Ski-Doo 2010 MX Z TNT 600
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
My 1980 ski doo citation has good spart and great compression and is getting fuel but still will not run it wont even fire even with starting fluid i think its timing is messed up so how would i fix this
The problem may or may not be timing. You say it's getting good spark but is it great? if the compression is as good as you say and your spark isn't strong it can be put out by strong comp. if it is timing i would get shop manuel for it. i can't find a micro phish on it so i'm not really sure where to tell you to start.
Mark
C.C. Motorsports
Feb 14, 2010 | 1998 kawasaki ZL 250 Eliminator
Sport & Outdoor - Others Logo
75 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
